camREEtrDEE
- August 26, 2023
- Fort Worth, TX
- 93 Ford Explorer XLT 4x4
Hello all! So I have a 1993 Ford Explorer XLT, and I just replaced the fuel injectors. They were all gummed up and some of the nozzles were cracked. After getting them to line up (which was a pain) and seat into the manifold, I replaced the fuel plenum gasket, and upper intake manifold gasket, and I put everything back together. After triple checking the vacuum lines and torque on the manifold bolts, I fired her up. Much to my dismay it runs even WORSE than before. E.I it barely runs. It will smoothen out for about 30 seconds then go back to almost dying, and cycle back and forth. Giving it a small rev helps for a bit. Now I know the injectors are plugged in correctly, and they are all brand new injectors from RockAuto that have been tested thoroughly.
However when I was replacing the injectors, I took the vacuum line off the FPR, I noticed fuel leaking from it, as well as the fitting on the regulator being wet with fuel. From what I understand, this drains back into the engine to be burnt, at the cost of running rich.
TLDR; Would replacing the fuel injectors make an already failing FPR worse? Maybe due to increased demand?
