Jefe's SAS | Page 13 | Ford Explorer Forums
Jefe's SAS
Originally posted by Jefe
Took me forever to finally figure out this one. I was dead set that it'd be metric. . but 10 is too small and 12 is too big, so I was like "great, who in the world makes an 11". . .I ended up going to the junkyard and pulling one to figure it out. Well, its standard. 7/16" coarse I believe.
Thanks! I was going through the same problem today, couldn't figure it out. I was positive it was a 1/2"...nope, so i try the 12 too big, and the 10 too small....
Thank you very much!
Got one more question for you Jefe
With your steering box, i assume you sleeved your frame? If so did you just extend the sleve out 1/4" on the inside so the box didn't hit the frame?
Probably more like 1/2", but yes.
AWESOME!!!!!
AHHHH, i think you're website is down.
Sweet.
Looks like you got the rear to flex more like the front. And that rear bumper looks nice.
How does it ride on the street? I know that RE advertises that this setup improves the on-road ride as well as the off-road. Since you are running the coil overs, how does it ride over stock? I am putting together a similar setup for my ranger although I am fabbing all of my arms from scratch and using johnny joints instead. It just would make sleep better knowing that this setup will perform better all the way around than my stock TTB. Thanks
Originally posted by jobunn
Sweet.
Its just that the front, being softer, flexes first, and then the rear flexes.
It is not so much fun to drive over 50 mph. The coilovers are so soft and flexy, that although the ride is nice and soft, the slightest wander or bump steer sends the body rolling. A sway bar would prevent this, but I've now gotten very used to it and its finally starting to be fun to drive again so I'm not worrying about it.
I will defininitely be using a sway bar w/discos. This truck is my DD for @ 70 miles a day. I run about 70 mph all the way and I want to be able to do that and not scare the sh*%t out of me when I round a corner. Thanks for the info. I also plan on fabbing up xj/tj style spring mounts and running 5.5" Rockkrawler brand springs.
Sway bar was definantly the best thing i've added since the conversion. I think Jefe would be better off with one, but his might handle totally different then mine did. I drive 50 miles a day for work on the interstate and i don't know how i did it before with out the sway bar. I used some stock XJ links, i'm going to try to pickup a set of quick disconnects in a few weeks.
I just can't figure out where to put one. :rolleyes:
Its either gotta go above (or through) the frame, or behind the axle (which actually might work well. . just thought of that)
Thats how the '02s are routed, If that helps at all;) :D
Mine mounted right under the radiator, bolted to the bottom of the frame and the arms of the bar sit right over the stock XJ connections. I doubt you have these since you're is a custom axle, but that's how i did it.
I thought about behind the axle too, but there was no way with the oil pan and my control arms. You arms might be longer, but mine wouldn't allow anything under there.
I still have the bolts in the frame that the stock bar mounted to. . .but the steering would hit it.
What about mounting the bar to the axle similiar to how the rear swaybar is setup? Just a thought, I don't know how this stuff works, gimmie something electronic :D
I thought the stock bar mounted to the big cross member??
THATS JUST SICK!!!!!!!!!!!!!!
Got Flex?
:D
Dead Link Removed
Amazingly she is still firmly planted on the ground. The front-left tire could go up another 1" or so.
And so the quest for a tall enough rock continues. . .
