So I have been bouncing around with different parts of the project the last few days ( I really should be pulling a trans so I can sell it on CL
) messing with getting some paint on the roll cage now that it's sitting outside, trying to finalize my final body paint color and started messing with swapping the 2nd gen dash components, into the 1st gen dash....or, to see if it even possible.
2nd gen Cluster fits perfectly into a 1st gen dash
I'll need to do some trimming on the 1st gen dash cover, but it doesn't get any better. I mean it looks like the top two bolts even line right up.
2nd Gen HVAC controls, again with a little trimming will fit where the Stereo use to be in the 1st gen Dash. A Double Din Stereo will fit below where the old HVAC and ash tray use to be. I'll probably turn the old 4wd switch into a winch controller or something later
The 2nd Gen headlight switch should fit in the same spot as the 1st gen switch, with a little bit of fab, and the 2nd gen dimmer will go under it where the 1st gen rear defroster switch use to be.
This just leaves stuffing all the wiring in the dash, and getting the vents to line up and work. I think I can make it work, but the left passenger vent may not be doable, the other 3 sort of line up. We'll see once I get the 2nd gen dash all apart.
