Yeah, do the jumper cable trick to it for a few seconds. That's the latest frozen bolt trick, I read of that for water pump bolts.
I had to hammer a socket onto three of the locking lugnuts of my 91 Lincoln years ago. I found the best size which required a big hammer to pound it on, and had to use a press to remove it each time. That was a Craftsman, about 11/16" I think.
We have to improvise sometimes. I just two days ago found a decent way to remove a frozen rotor from my 98. The right rear wouldn't come off, twice now doing the brakes. The center section was stuck on to the axle, likely a too small hub hole, the rotor the truck came with. I cut it off with a rotozip 3" cutoff wheel. It took about 30 minutes, I cut adjacent to each stud where I could get the tool in well. I ran it down next to the axle hub without hurting it, until I got through the rotor. With five slots cut that way, finally the rotor would move, it took about 10 seconds of yanking after that. Hell of a thing, I don't know if it was the wrong rotor, but it's scrap now.
