No more gauge needles synchronized dancing!
Replaced both battery cables today. Ended up ordering a negative cable off Amazon, as nobody had one anywhere near me, or didn't even carry them. Napa found 1, and I mean 1 cable only, in MN, with a week wait. Said meh to that. Took less than 2 days from the Amazonian tribe to arrive.
Cleaned up all the old acc wires I had running to the battery, with new wires and connectors. Shrink wrapped, and Friction tape on all. Found one broken ground strap to the hood. Clip busted off. I just replaced it with a wire connector and used a fender bolt to ground it.
Hardest part of the entire deal, was getting the damn hot wire back on the starter. Why the heck did Ford make that damn thing so hard to work on? lol I lost a nut for it somewhere on the rig. It didn't fall to the ground, and I searched for what seemed like an hour. Just replaced with another. I'm sure if it fell in a pinch point, I will find it then.
Oil filter says 2/14/19 on it, but haven't even put 3k on it since. Oil is still clean, but I have been adding about 8 oz/mo in it. lol Underside shows it too.
Pulled a couple plugs as well. They looked great. No sense replacing them now. Just put the new ones back on the shelf, for another day.
While I had the wheels off, I reached in and was able to tighten the back valve cover bolts a little. I think it's leaking from them. I replaced them with the blue felpro's when I did the intake gasket. I guess they didn't seat so well, even after snugging them down again.
With the battery out, I discovered that the lower front of the filter box is busted. There is a triangle hole in it. I can let it go until I source a new one for it, since the filter will catch stuffs. Only thing I can think of is the tire hit under it when off roading in the past.
Thanks for taking Labor day, so literal Pugly! lol
