On second thought, after a (possible) screamin deal from a friend I may be going with a waggy front/ full width 9" or 8.8 rear.
4.88's with a waggy leaf sprung with maybe a leaf removed so it dosent look stupid on 33's untill I get some 36/37" Bias Iroks or Boggers. Although I havent ruled out the possibility of running some 2" blocks and trying to stuff 40" michlin XL's in there. That route would acually be cheaper, but I would go to 5.13's and cromo's. Or run stock shafts till I break one (first trip or two) and then go cromo.
Swapping the outers to ford 5 on 5.5 to match whatever rear I get. With NO ADAPTERS
*Stolen from Mr.N's
http://77cj.littlekeylime.com/flatop_knucles.html
Option 1: Use a mix of Chevy/FSJ and Ford parts. You'll need a Chevy or Full Size Jeep Dana 44 flat top knuckles, spindle, caliper mount plate and outer axle shaft from a 73-76, see chart for exact years and BOM. To convert these to the Ford 5 on 5.5” (also the same bolt pattern as a Jeep CJ, Scout II and many other vehicles) you’ll need a 1976-1984 or 1987-1995 Ford hub, rotor and bearing. My suggestion is use 76-79 parts, but you can use an 80’s Ford IFS Dana 44 (minus 1986 and some 85 as they had a unique style.) Pull the hub with the bearings, rotor and lock-out. Any standard Dana 44 ½ ton or Chevy ½ ton 10 bolt axle lock outs should work, and spare are always good.
Option 2: Use only Ford parts. One catch, you'll need a 1/2 Super-Cab knuckle, see above General misconceptions table for reason. If you have a nice Ford 1/2 ton axle with new calipers and rotor I suggest just find in a knuckle from a 1/2 Super-Cab, as that is the only part you'll need. (Note to self, check spindle part numbers in Dana book to confirm this) Or you can just grab the entire Knuckles Out from a 1/2 Super-Cab and bolt it up to your inner knuckle.
BTW I have no plans to go hysteer at this point, the Skunk dosent so why should I?
