- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
So glad to hear it!!!!!! It’s alive!!!!!
Winning the war
Winning the war
now that i have seen a couple of pictures, i never knew that part was a valve lol. i had to put a different one on (black not grey if it matters) because the grey one grew legs. i did notice when i drove it the last time (with the grey one that vacuum would drop when i had the brakes on.Your booster has a vacuum leak?
With line unplugged the one way valve is Doing it’s job?
With it plugged in you lose vacuum, sounds like your booster may have a large leak?
The Brake Booster Check Valve: What You Need to Know
Want to learn about the brake booster check valve? Here’s what it is, what it does and how to fix the valve when it’s failing.www.repairsmith.com
Valve maybe sticky which is why it works at times not at others?
Just thinking out loud here
Does holly ahve the same style open loop/closed loop system, meaning when cold its in open loop?
Didn't the guys tune while you had a vacuum leak?
I'm wondering if thats somehow part of the issue you are seeing.
I'm not sure the sensor is heat soaking Tim (well, maybe its part of what you are seeing).
At idle, your blower is still creating boost (heat), and that bypass valve is open. With the valve open, the boosted (heated) air is recirculating.
Honestly, at low load you have nothing to worry about. Its higher load stuff that can ruin a motor with high iat's.
The heat soaking thing can be debated all year long. It would obviously help if you could get that air filter out of the engine bay. but then again, temps go down when moving. Is it worth changing anything?
