- January 22, 2007
- selkirk, manitoba
- 98 supercharged 347 sport
was finnially able to go for a ride in evil today. also wanted today because its around 28C or around 80F so i would see what kind of heat it would make. well.....
that was a couple of mins after getting on it (top right corner) and i dont mean going through 1, 2, and 3rd. saw it wick up to 180F. moving the nozzle just before the rotors didnt make any difference. i might have to figure out a way to put it after the rotors or under the blower. was about to order a intercooler but they would have to make it, which i knew and would be a week out, but they also didnt have the water inlet rails either.
cant remember if i posted it, but it would come from here.
its 2 1/2 inches tall. hood clearance should be ok, but what i overlooked was firewall clearance. will have to look at that a little closer.
i also made a different pulley bracket. forgot to take a picture of it before i put it on, but looks way cleaner then the one im used to looking at.
with that i also kinda cut up a different thermostat housing. because of holley making this intake so the thermostat is pushed out farther, the bypass hose rests directly on it. had to cut the hose back a far as i could, and also the pipe for the bypass as well. its kinda better, but still up against the pulley bracket.
1500 HP Air to Water Billet Intercooler
1500 HP Air to Water Billet Intercooler Pre-order. No refunds or cancelations. These coolers are an awesome solution for packaging and simplifying your under hood layout. Track and Dyno tested to drastically reduce the intake temperatures by up to 200 deg. Utilizing 2 female -12 orb ports per...
417motorsports.net
