allmyEXes
- February 6, 2016
- No. Alabama USA
- 1997 Blue Ex 4.0 SOHC
- Callsign
- KAGG 3611 (CB)
It your link, I read something about it is pressed on. You may have to use a bearing separator tool like this and a hydraulic press to remove it.
I'm just guessing though. Later today I'm sure someone else will chime in.
Kukko 15-0 Bearing Separator (3/8
For removing ball bearings, roller bearings, inner races and other tight parts if there is not enough space to use pulling hooks. Pulls diameters between 3/8" and 2 3/8" Product Data Sheet Use with Kukko 18-0 Pulling Device Description The sharp blades enable flush parts to be removed where...
probearingtools.com
