Oh-
while you are here-
Don't forget that the high stall will create a lot of heat. See if there is a way of manually locking the torque converter in low range??
What turbo are you looking for? I have a used turbo from an Eagle Talon that was planned to be for a twin turbo 302. It's slightly ported and in unknown condition. Would it do you any good, I gave $100 for it long ago?
Don't forget to get it dyno'd and get some times down the 1/4 mile track when you are done.:
I will install the Tiffany mod first you OLD fart!John you really don't wanna play that tune, it would be embarrassing, if I put pizza cutter on it, and spanked the **** outta your Limited with a 4 popper.
Jeff - :navajo:
Did you get a decent daily driver yet?
No sir I didn't, the BMW fell through he had no place to keep the boat, the 2nd gen Explorer I was going to trade the boat for fell through, the guy wanted a Cuddy Cabin insted of an open bow, I was going to trade Justin for his 1st gen, and on the way home from the B-day/Halloween party the transmission crapped out
Maybe this is a sign, that I'm stuck with the damn boat
But I take Lil Mrs. to the airport tomorrow, and so I get her GT for the next three days, so that'll save on some fuel right there. *insert Smartass Ben comment here*
Ok well I just got through printing off 31 pages of schematics for the Turbo Coupe, and coupled with the Electrical Service manual for the Navajo from Ford, looks like I'm in the green for a wiring launch
I'll also be doing the Mercon V conversion in this transmission too.
Jeff - :navajo:
Now Ben why would I want to put that heavy boat anchor in the front of my crawler, I'm dropping nearly 100lbs. off it's nose with the 4 popper, and with a fuel cell or BII trank mounted in the rear, I'm actually going to have a more even wieght distribution front to rear, let alone side to side.
As nice as that DOHC is, it's not for this application, now if I was doing a street sleeper, I would highly consider it.
Jeff - :navajo:
BTW the little kitty's have nothing to worry about it's that damn retarded dog that needs to worry.:
