- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
the v6 CMP uses a cast gear. the explorer version uses a steel gear that works with roller cams. i think that billet cams need the bronze gear? i didn't get a billet cam. i will be using the explorer gear.
The same steel gear used for roller cams should be used for a billet cam. A bronze gear should be avoided as much as possible. The real problems with some distributor gears are related to the fitment, the relationship with the cams. That gear mesh must be just right, or any gear is going to wear out really fast. The bronze gear was a good idea at the time. Now though the same steel gears that are most common in stock engines, they work fine for any roller or billet cam. You just have to avoid cheap cams actually.
The billet cams are simply the best, everything else is a cheap product, literally. Those others are SADI cores, meaning cast/poured/pressed etc, a mixture of weak materials. They are all very easy to break, they all have very inaccurate valve lobes(events). If you timed the engine using the ideal method of a degree wheel and the two front lobes, you'd think it was perfect. Try that some time, then time the cam again using any other pair of cam lobes. The cam timing will be different, each pair of lobes of a SADI cam are going to vary a little. That is bad for performance, and for getting the ideal tune.
Basically a custom billet cam is perfect. All of the lobes will match exactly. You can time the engine with a degree wheel using any pairs of those lobes, the timing will be exactly the same. I paid $100 extra for my custom cam to be made from billet instead of a SADI core. That is money well spent, it can survive blown engines much better than a SADI core cam.
Sorry to rant, I try not to get started on cheap parts. Back on topic.
