sirhk100
- December 19, 2000
- las vegas
- '91
Okay, like mentioned above... If I was truly building a high speed rig my rear shock mounts would be drastically different. The thing is, I owned the same vehicle with a fairly similar setup about 10 years ago and amazingly it did pretty good. I had some very agressive shock valving in them though. These will be the same and in theory should actually work better then my old one since these shocks are bigger and the bypass action should help out quite a bit too. Down the road maybe next winter I might get crazy and change it up but for now these will be fine. The whole setup is bolt in so it's easily removed for any future changes if I go that route. One thing is for sure, the shocks will stay mounted under the cab no matter what I do down the road. Having the cab 100% stock inside is a priority on this build. So with that said... Some pictures...
I'll clean this up some a bit later when I get going on body work but in the end it will be covered by fiberglass anyways.
Folded under the fender and welded up. I still have a few minor spots to finish up on these as well.
Drooped out. The mounts actually have a top plate going between the tabs and then actually a backbone/shark fin type of gusset and are fully welded 360 obviously. They're just tacked for cycling in these pictures...
Compressed
Proof that is should move up and down... Or at least down! LOL
http://s67.photobucket.com/user/sirhk100/media/Expo/100_1487_zps3f49a954.mp4.html
Assembled and on the ground.
Ride height on the rear.
Still have a bit more to go on the rear. I want to add a 3rd mounting bolt on each side of the upper shock crossmember. Need to plumb up the brake line and bleed them. Bolt up the driveshaft. Setup a breather line for the rear axle and get some wiring stuff dealt with also in the rear. I need to mount the reservoirs as well obviously.
Off the top of my head though, I think that's all I really need. I'm hoping to knock all that out fairly quick and then move on to mounting the rear fiberglass. If things go well this weekend with all of that maybe I can get really crazy and turn it around so I can start on the front end before the weekend is over. I'm not sure how long it's going to take to do the fiberglass though.
Compressed
