mrdot
- July 27, 2016
- 15 & 16 EXP Int. 3.5T
hello, just wanted to let you guys know that there is a loser selling modified .ab data though a website to disable the double honk. This can be done without that or dealer programming by using a program called FORscan. 2017+ do not try!
See this thread,
http://forscan.org/forum/viewtopic.php?f=5&t=2331
** This is the route to go for these modifications! don't buy any hexed .ab files from online vendors. The Ford dealers will not apply them most of the time and it will end up costing you their hourly rate! **
This can be done using FORscan: (you will need to register and get extended license)
No IDS or dealer programming!
_____________
Download and install FORscan:
http://forscan.org/download.html
OBDLink MX Bluetooth Scan Tool:
https://www.scantool.net/obdlink-mxbt/
and a bluetooth enabled laptop.
The edits are at: (confirmed with 2014 explorer)
(2011-15 model)
BdyCM 726-16-01 0111 56 (Double Honk Enabled, Default)
BdyCM 726-16-01 0101 46 (Double Honk Disabled)
# 3rd digit number is 1: double honk enabled
# 3rd digit number is 0: double honk disabled
(2016- model)
BdyCM 726-41-02 0001 0000 0071 (Double Honk Enabled, Default)
BdyCM 726-41-02 0000 0000 0070 (Double Honk Disabled)
# 4th/12th digit number is 1: double honk enabled
# 4th/12th digit number is 0: double honk disabled
See this thread,
_____________
(2011-15 model)
(2016- model)
