21Robbie21 SAS | Page 8 | Ford Explorer Forums
21Robbie21 SAS
ok the axle is complete except for new diff fluid, it looks badass too with the black housing and red knucles and silver rotors and red diff cover, but unfortunately i cant find my camera USB cable, so no pics, tommrow the tear down starts, im having a couple friends come over
ive got a concrete slab in my backyard next to a bottom porch wher i am going to do all the work, that has a basketball goal, so i have to drive through my neighbors yard to get there, that way it wont look bad, plus my dad wouldnt evn let me, leave it in the drive way, and im going to rig up a tarp over head for shade.
but anyways, gimme some tips on the tear down, what extra tools will help, what shouldnt be comprimised etc etc?
still working on getting hangers, brake lines, and whatever steering lines ill need,
shocks and gears are at the bottom of my list, i just want this thing drivable with the new suspension as quick as possible, i leave for UGA on august 13 and i know its a crazy goal, especially for someone who is cluecless on what hes doing, but ima try my best, plus ill have the advantage of only working like 2-3 days 20hrs over the next month at home depot so i can use the rest of my time on my car
oo eye candy
1.23" wheel spacers/5x4.5 to 5x5.5
spring perches front and rear, u bolts and plates and shock mounts
Looks like you're making great progress. Keep up the good work.
Did you already re-gear front and rear?
He hasn't regeared anything yet. Really, it would be a waste of money to regear the front end when that money could buy him a t-case. ;)
.... that he can't really use without regearing the front.... :p
no matter what... it's just a matter of order that you spend the money. either way.. both have to be done to call it finished!
Eh, it depends. Run an NP435 tranny with almost a 7:1 first gear and it doesnt really matter whats in the transfer case. :D :p
except he still won't be able to use the front diff any! I don't think the diffs would like that being different ratios.
Run shorter tires on one end then. :p Anyhoo, it would be hard to bolt a 435 to a 4 liter anyway. :D
ooh.. yeah. I like that idea of the different size tires. That would be blingin
sweetness man !!! if ya need some welding or teardown help give me a call :thumbsup:
does anyone know if the brakeline setup in the rear is different for first gens and second gens? because i can find the extended lines for the first gens but nothing for second, and it would be easier just to order some then have some made.
I cant answer your question but i just bought a waggy axle and 6 inch leaves for it. got the axle, hub to hub, the leaves and the u-bolts all for 125! :D he also put new ball joints and u-joints in it recently. This kid i go to school with works in a junkyard and had this setup under a s-10. he removed it to make it a daily driver again. the axle is already cleaned up and the perches have already been flipped since he already used it this way. I just hope the width is the same since he had it under an s-10. I almost feel like im stealing it.
lol here u go :p :
haha... the cookie
early on
end of today, this crap is a lot harder than you guys make it look in your one day jobs with pics at the end of the day, thanks to some help from BMXKING i got atleast this much done today.
im not sure if you other second gen guys have had a this, but i had a tow hook mount bracket(even though i didnt have stock tow hooks) that was welded to my frame in four places, not fun
what a ***** VVVV
a lil paint on my rusty springs
section-like cross member
1st gen steering shaft on steering box
ive ordered RE 1555 extended brake lines for the front
also i got f250 shock towers on the way
still waiting for my procomp 8089 16x8s to show up too
still wondering if first gens and second gens have the same rear brake line setup?
does anyone know the best way to order just the steering extension for a first gen bodylift?
thanks
Removed rear springs, took out one AAL(had two took out long one), flipped the pin and pressure washed and painted them.
Also im removing my warrior shackles and putting my old ones back in, so i painted those too, because that all im good for is painting things :D
Recieved my f250 shock towers and RE 1555 ss brakelines
also picked my some length of rubber hose for axle breather hoses
by the end of today i should be done with the stupid ass grinding of the front, and have the SOA bolted up. Welding is going to begin thursday or friday. One thing thats worrying me right now is i still dont have my fricking wheels so even if i finish everything else itll still be sitting on jackstands :mad:
but hopefully theyll show up anyday now
welcome to the club!
btw.. how many rugs do you have laying around at your house?!?! :confused:
its the unfinished part of my basement, so the floor is concrete so when im walking and sitting, for ease of clean and ease of sitting parts, i put out a bunch of old rugs and blankets
did you get that welder ?? what kind is it btw ?
