Ronin8002
- March 23, 2003
- Virginia
- 2008 XLT Ironman
So just a little update.i called and talked to the guy at 3800performance and he is going to build me a custom charger.he is filling a couple of the holes i won't use and porting and polishing the whole unit afte.he is also milling down the snout to fit smaller pullies.there is some other stuff getting done to it but that im keeping a secret till at least i get it back and only if you can tell by the pic will you knowi helped out my buddy Chris(boomin ) with picking up an explorer after a 10hr straight trip so i now have a sohc oil pan and all parts for it.figured it may help a little and why not it was free.so next sat i will be trying to put in the fuel pump and sohc oil pan.im going to try and do it with out removing the engine,i have a 3" body lift and 5.5 so i should have room to crank the motor up pretty high to get it off.do i have to use the sohc pump and pick up or can i use ohv pump and pick up?or can i use sohc pick up on my ohv pump?i have a high flow pump so i don't wanna get ride of it?!!!!
check with Brandon96...he bought my old motor and SOHC pan.
