- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
okay working on instrument cluster and its wiring
After deciding on a solid path forward I pulled the trigger and started hacking into the trucks wiring.
Basically I am using a 2005 instrument cluster and its wiring pigtails
In 2005 the cluster was similar to an 07 cluster in appearance and wires, however it also still had 14 additional wires for inputs from the truck
As a result I ended up cutting off the 2007 wiring connectors and replacing them with the 2005 connectors. The 75% of wires that match up got spliced together. The other "new" 14 wires I will have to wire each circuit on the truck side of things.
Basically I am in control of things like the ABS light, OD off indicator, tachometer and coolant temp signals, and more........
2005 ranger pigtails with each wire identified
05 and 06 clusters labeled
No going back getting ready to cut the 07 connectors off
Splices done now to wire the truck side
Here is some eye candy for you guys while I work through this
There maybe weeks and weeks of wiring here on this truck now to get everything working and sorted, while this is happening I will be putting the rest of the truck together
Suspension with its new limit straps, and adjusted all cleaned up ready for wheels and tires
Drivers limit strap installed
Here is a shot showing both suspension braces now installed
