- November 29, 2000
- Location
- USA
- San Diego, PRofK
- 1994 XLT
I spent some more time under the back of the Explorer, and I don't see how welding the cross member to the frame will help the wiggle of the rear bumper. I don't feel any movement at the seam between cross member and frame when I'm kicking the tire carrier and pushing it up and down. I'm going a different direction. I have bumps on the back of both the gas can and tire carriers in case they contact the rear hatch. They are both about 1.5" away from the hatch, so it doesn't happen. I found some thicker bumps and cut them down so they contact the back hatch when the carriers are locked down. There is still some wiggle, but it's less. The bumps push into and flex the sheet metal of the rear hatch. I made two stiffener plates out of some stock I had here. Waiting for the paint to dry before I rivet them to the hatch. I think this will help more than trying to stiffen up the frame.
I thought about using some bushings I have here and making two pinned mounts to connect the carriers to the hatch, but that won't work. The movement of the bumper will eventually tear up the sheet metal of the hatch, and it will be difficult to open and close the swing outs.
