Hi guys!
I've been on this forum for a while and thought it was about time I made a registry for my X!
The 1991 XLT has been mine for almost 1.5 years now and using this forum as an incredibly useful resource I've been able to do quite some stuff myself, even though I had no previous experience working on cars at all.
The current state of the explorer (step bars have been removed, though):
It's basically stock, but was in a bad shape when I bought it. Since I've had it, i have replaced:
Since November 2011
- Headlight switch
- the waterpump
- oil pressure switch
- front shocks
- front wheel bearings
- removed the AC (wasnt working, doesnt get hot enough here often enough to really need it)
- thermostat
- replaced the alternator
- fixed electrical windows
- cleaned MAF, IAC and tons of other stuff
- tightened lower intake manifold bolts
- replaced a transmission mount
- New spark plugs (Also the rear passenger one
- Replaced a u-joint in the rear driveshaft
- Replaced auto hubs with manuals
- Replaced fuel filter
Update April 9, 2013
- Replaced rear shocks
- New 95TM heads, replacing the 91TMs
- New rocker arms
- New Pushrods
- New Lifters
- New spark plug wires
- Replaced switches for central locking/windows
- Replaced rear door panels
- Greased rear power window tracks
- Replaced TCC solenoid and about 8 qts of ATF
- Replaced power mirror switch
Update April 17, 2013
- Fixed power door lock switch at drivers side. (Note: drivers and passenger side switches are NOT interchangeable)
- Fixed rear driver passenger inner door handle
- Finished installing front tow hooks
Update May 12, 2013
- Adjusted overdrive band
- Replaced and regreased front outer bearings
- Lubricated driveshaft spline and some linkages here and there
Update May 14, 2013
- Rear differential oil refresh
Todo
- [Done] Install trans temp gauge
- Connect trailer wiring
- Replace O2 sensor (no codes, but I have a new one, and the current one is stock, I believe)
- Replace motor mounts
- Fix A4LD no TCC. Had the solenoid replaced, but still no lockup
- Remove after market alarm system
As the thing is guzzling coolant like it's nobody's business, and I have as of yet been unable to find any visible leaks, I'm inclined to believe it's the head gasket/heads. Hence I've ordered some parts from rock auto
New rear shocks (monroe sensa tracks), new motor mounts, couple of oil filters (3.5$ on rockauto versus 15$ here in the Netherlands, gotta earn the shipping charges somewhere
) ditto for some air filters. some bearings, an upper engine gasket set, head bolts, filter for the transmission (A4LD), O2 sensor, new spark plug wires, and factory-new 95TM heads (got them from someone local. Not sure if I needed them but as they were cheap (150$ each) I figured why the heck not, instead of risking finding a crack when the current ones are off) If I've read correctly, the 95TM heads will bolt on my 90TM block just fine. fingers crossed
Rocker arms and pushrods were already ordered previously, and will also make an appearance on the new heads...
I bought a T-55 socket, only need some other minor parts such as exhaust manifold bolts, I expect having to cut them off.
Do I need engine assembly lube (which is hard to find around here for some reason), or can I also apply some oil just before putting the valve covers back on?
Now all I need is a few days off to do this job at the slowest pace possible
Since November 2011
- Headlight switch
- the waterpump
- front shocks
- thermostat
- New rocker arms
- New Pushrods
- New Lifters
Update May 12, 2013
Update May 14, 2013
Todo
