blob19
- November 19, 2016
- Midwest
- 2016 Interceptor Utility
It may be obvious to some, but I went ahead and tested and confirmed:
The settings @ FORScan 2011-2018 Explorers under the tab "Powerpoint Timeout" (BCM: 726-39-01 AAAA BBBB CCCC), the "AAAA" is completely customizable - not just the 6 options listed on the spreadsheet. The value for these bytes in the AAAA position is the hexadecimal representation of seconds that you want the accessory power to stay on after the key is turned off.
For example, I wanted mine to stay on for 3 hours for a bit of parked dash cam recording, so to convert 3 hours into seconds: 3h * 60m * 60s = 10800. 10800 decimal converted to hexadecimal (Decimal to Hex converter | number conversion) is 2A30. I set AAAA to 2A30, and confirmed that the accessory power indeed stays on for 3 hours after I turn the key off. This effects the front 12 volt outlets, and I believe the overhead red+white LED dome light.
The map lights and cargo light are on a different timer which I'm not sure how to configure, but it appears to be a 10 minute timeout.
