j_mazala
- July 16, 2006
- Bay Area, CA
- 98 XLT
I'm having the same problem with the draglink hitting the passenger side spring but there are a few things that you can do to try to fix it.
First is a spacer for the high steer arm, they sell them in 1/2" and 1" I think but then you'll need longer high steer studs and with the spacer plus Sky tall arm thats a lot of leverage on the knuckle/studs/balljoints and you run a higher risk or parts breaking or wearing out faster.
Then you have the option of kicking the castor angle up a few degrees to effectivly bring the draglink higher above the spring. Downside of this is too much castor angle can cause adverse handeling characteristics.
What I've chosen to do which I havent actually done yet is to run an even flatter pitman arm. Right now I have an arm off a Wagoneer that is 6.75" hole to hole with a .75" drop or so. I grabbed an arm off an 80 2wd F150 Custom about a month ago that is 5.75" long that actually has a .25" rise to it. Im hoping this will be enough to get the link off the spring under flex. Downside here is bumpsteer from not having the draglink flat, but I guess I'll see how bad it is when I get it put on. Need to ream out the hole for the Chevy TRE first.
This problem mainly stems from the spring not being level from front to back. The real way to fix would be to either lower the front mount which aint gonna happen because then it would just be a rock anchor and kill the approach angle or have the shackle go through the frame like most of the toyota guys do or get a set of shackle sliders from DIY4x4 or Liquid Iron Industries which would bring up the rear spring eye a bit. But all my junks fully welded in so I'm hoping a workaround with the pitman arm will work for my needs. Good luck gettin it all dialed in and ditch the body lift!
