- September 1, 2002
- Lake View Terrace, CA
- '91 Navajo '99 X '19 Rngr
So here is my codes to deal with
B1600 - transponder Signal Not received
B2103 - Antenna not connected
P1000 - drive cycle: not worried about this
P0500 - Speed Sensor: not worried about this
and I get a bunch of other random codes...like it can't find the rear defroster now.
and the air bags aren't responding
It is possible i got to bad ignition halos? I've tried two I pulled from the JY and both show the same code. They are the same part number as original. Do I just go buy a new one from Ford, or could this be a ground issue somewhere?
The other issue I wonder is cluster linked in PATS? I swapped in a '01 Spot Trac cluster into this. The '97 I had, needed a new cluster and I cannibalized it from this. Did I just screw myself over by doing that?
I remembered I swapped JP's and did not have issues, but maybe I just swapped the gauge faces
