I thought I was going to at first, but the more I think about it, the less I want to with the leaf spring setup. Would seem strange, because I know people would purchase it.
With the leaf spring suspension as I have it set up, a small movement of any of the brackets and the axle is not where it should be anymore. This includes welding up new ones to make sure everything is in place damn near exactly. I just don't want to get into it with the leafs.
As for the coil setup. When I get Josh's working and if I like how it comes out, I will probably sell that as a kit. With only two real brackets (trac-bar and new tranny crossmember), it would be difficult to change the position of the axle relative to the chassis.
Either way, the steering setup requires welding as you need to sleeve the frame for strength as does the tranny crossmember issue with leafs. With the coils, the issue disappears.
So to clarify. No leaf spring kit. Potential for a coil spring kit using a D30 axle or a D44 with the same mounts as an XJ/TJ.
