Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
Robb's SAS
- Thread starter Robb
- Start date
Add an avatar, upload photo attachments, and more!.
oso_polar
- April 23, 2001
- Caracas, Venezuela
- '99 Explorer Sport
Hey Coryl, my friend Chola, had the same problem with the front driveshaft hitting the cross member, I know I promissed some pics, but he is always busy, so that will be a pic too, I thinking something about cutting it, and welding a new piece of metal, or something like that, I will try to figure that out as soon as possible...
Muskrat
- March 9, 2002
- Califon, NJ USA!!
- 97 Ranger STX
in one of the rags, I think Fourwheeler, last month, they adress that issue while indexing a superduty t-case what the essentially ended up doing, was cut the cross member, ans welded in a half piece of 5" diameter .5" wall tubing, and they said it was very strong. Of course, all measurements must be taken from the center piont of the front output shaft on the case, measure twice, cut once
or in my case I cut it twice and it's still too short
anywho, I think I'll be doing something along those lines
jshexplo96
- May 9, 2001
- Charleston, SC
- 95 EB 4x4
That def looks sweet Rob!!
DasFrem
Elite Poseur
- February 21, 2000
- Portland, OR
- 2 '97 sports
That's the front crossmember. Since you have to cut out the old crossmember that held the front diff and the IFS components you need to replace it with something that's out of the way of the SFA and provides a little structural integrety.
cdsl227
- June 25, 2001
- Brooklyn, NY
- 2001 Explorer XLT
<--- Dumb as a box of rocks!!
Since it was already at skyscraper height- did you get any closer shots of the steering setup??
I know this is simple stuff to you guys, but I need pictures...
Cause if I try to get this done in NY...it'll be paint by numbers.
JoshC
Only rolled it once honey
- May 1, 2000
- Culloden, WV
- 97 4d OHV
Coming along great Robb. That looks really good. I hope you don't get to attached to those tires!!! haha.
I'm in Oklahoma City right now and i'll be coming back home the second weekend of march, and i'm hoping to stop by Corys and see the progress he has made. Could see you there, just depends on how Corys work is doing.
CoryL
- January 15, 2001
- Louisville, KY
- 94 Eddie Bauer
Brakelines (not extended, that's up to Robb) are in.
Driveshaft is being lengthened. Should be back tomorrow night or Wednesday morning.
Still have to figure out the tranny crossmember. Shouldn't take but a few hours between Tuesday and Wednesday.
Going to change his oil (low pressure, he's probably a few quarts low
) and bleed the power steering setup.
Then it gets delivered to my house to wait for him to pick it up.
While I am finishing Robb's, I start Josh's and another project coming in. Full hydro setup on a first gen sport SAS.
cdsl227
- June 25, 2001
- Brooklyn, NY
- 2001 Explorer XLT
Cory, quick question are you compiling a list of components that you will be putting together as a "Kit" to sell??
The more components included the better...
You could price it based on the completeness of the kit...I would surely be interested in purchasing something like that.
Thanks! And GREAT WORK!! I know Robb must be happy as hell...
CoryL
- January 15, 2001
- Louisville, KY
- 94 Eddie Bauer
I thought I was going to at first, but the more I think about it, the less I want to with the leaf spring setup. Would seem strange, because I know people would purchase it.
With the leaf spring suspension as I have it set up, a small movement of any of the brackets and the axle is not where it should be anymore. This includes welding up new ones to make sure everything is in place damn near exactly. I just don't want to get into it with the leafs.
As for the coil setup. When I get Josh's working and if I like how it comes out, I will probably sell that as a kit. With only two real brackets (trac-bar and new tranny crossmember), it would be difficult to change the position of the axle relative to the chassis.
Either way, the steering setup requires welding as you need to sleeve the frame for strength as does the tranny crossmember issue with leafs. With the coils, the issue disappears.
So to clarify. No leaf spring kit. Potential for a coil spring kit using a D30 axle or a D44 with the same mounts as an XJ/TJ.
Similar threads
- Replies
- 60
- Views
- 7,260
- Replies
- 52
- Views
- 14,395
- Replies
- 22
- Views
- 3,769
- Replies
- 272
- Views
- 44,896
