IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
- 1998 Ford Explorer
I think a grade5 is good enough in this situation.. two 1/2" grade5 bolts should be able to withstand about 9k lbs of sheer on that one side.
I think we also have to keep in mind that in this situation, assuming the bolts are at proper torque specs, all of the stress is not placed directly onto the bolt - but rather, most of the stress is handled by the two mating surfaces which the bolt is "clamping" together. A good example of this are the "high steer" arms where the torque from the tie rods are not directed to the high-steer arm's studs, but rather the surface between the high steer arms and the flat-top steering knuckle. The studs, and its accompanying nuts, is merely there to provide the proper clamping force.
