- January 22, 2007
- selkirk, manitoba
- 98 supercharged 347 sport
This thread has multiple ideas. Have a look.
Explorer 5.0 EFI w/roller rockers what valve covers? - Page 2 - ClassicBroncos.com Forums
Fresh air needs to come in one side valve cover and go down into the crankcase and up the other valve cover through a PCV valve then into your supercharger inlet.
The oil fill cap tube in the picture of your valve covers is where the air goes in, so the other valve cover is where the PCV valve needs to be.
I like the one in post 21.
i looked that over. to me it looks like they talk more on valve covers then a pcv system. however, so what your saying is i can run a breather on one cover and run a tube to the intake from the over cover?
like, a tube can go from this one (if you look i have a plug on it) going to the intake
and a breather on this one? will it toss oil out however?
i also solved another small problem. cant remember if i mentioned but instead of bolts, i am using a carburetor stud to bolt or sandwich the pan and blower mount to the motor.
what i plan on is to be able to lay the intake to head gaskets down, then the valley pan using the studs to line everything up. then lay a bead of silicone down to seal the pan to the blower mount. i wanted to be able to drop, the mount, rails and blower down as a unit using the fuel rails also as something to grab onto (hopefully it will be happy, time will tell).
2 things i didnt like about the carb kit i am using (moroso kit 37961) was that there wasnt a lot of threads that went into the heads, as well as the studs sat a little too tall for me to get a socket on top to tighten everything down. me not being a expert, or even a novice at machining wasnt sure if you can run a thread chaser down them being what i would think was harden steel. well, it work. solved to problems at once. was able to add 1/2 inch of threads to the bottom of the studs, and also lower the studs on top being able to get a socket on up top so i can torque them
