Well, isn't this all about trying things, ???
I hear a lot of grief-" Chevy parts on the mounty? absurd!!!"
I see all kinds of parts taken from other vehicles and fitted into out trucks, So what?
Let us not forget, one of the meanest rigs being built on our forum uses a chebbie rear axle. Well, it will if it is ever complete--
Ever complete, that is the point. When will it ever be complete?
Let's please discuss possibilities here. I would like this to be an open minded discussion. Nothing has been cut, nothing in stone, just pure discussion.
I would like at this time to point out some things I have observed, and measured.
Looking at my stock suspension front plow, I see about 6" of good ground clearance. This could be increased to a whopping 8" maybe.
Now, moving to the front 1/2 ton suspension box on the blazer with only 35" tires, I measure a whopping 14" or more of ground clearance.
Comparing the stock dana 35 1/4 ton components to the blazer 1/2 ton components, I see a huge advantage.
I have been told, but need verification, the stock blazer IFS front is a dana 44, in fact stronger than because of the use of CV axles.
OK, moving on, looking around the design is similar. I feel if it can be fitted it will equal the Dixon brothers long arm kit. In fact, comparing the Dixon components, and their use of the stock hub and knuckle, I feel this blazer alternative to be stronger. Not to mention the replacement parts are all off the shelf , common items.
The front disc brake system has an ABS sensor incorporated.
I know it sounds confusing, but in a nutshell, the parts which need narrowing ( approx 5") are 2 drop bracket cross members made of flat stock, which can be plated, The trac bar support bracket tube, the passenger IFS inner axle and passenger side tube extension.
The lift kit will be free to me. The donor truck will be getting a solid axle. This gives me even the cut off bracketry from the blazer to use.
Yes it will be an effort. But think about it. A dana 44 pig tucked way high, and the extra strong cv axles, hubs and 35's on IFS!!!!!
Also, a very important factor, is, the use of the stock explorer steering rack, and, possibility of hydro assist to it due to being able to attach a drag link from all the added clearance.
This really could work you know. The more I think about it, the more I want to try it. Just to be different.
They make no harmonic balancer with crank trigger for 347 engine, yet I tracked one down.
There are no headers made to fit Edelbrock heads in an explorer, yet I got some.
There is no egr tube to fit these headers, and aftermarket intake, yet, I was able to work that out also.
Yeahm those are little things, yet,
I see a lot of things being made on this forum. Now it is my turn to try the big stuff.
Okay the other side of fence,in the solid axle's back yard now. And as I see it,,,
think of what a good dana 44 would cost-in fact, if I was to go the route of a solid axle, then, a 60 would be in order. This will require a lot of fabrication either way. The cost of adding a solid axle can really add up. After mounting and linking, I will still need to figure out how to hold it all up. Might as well do coilovers if you go to the effort--
In summary--
Trying to fit in the free to me suspension lift will be a low cost experiment, until I go to shortening the front axle. However, I think I will know if this will have a chance at success before I get to that point. I will have lost nothing but time, as, I will need to strip the frame for whatever ends up steering this thing.
Anyone have a good idea where to check about getting custon axle tube and axle work performed?
