We would be happy with pictures ofWere going to do a little more of this tonite
I just realize that I did not post any picture's of the first set up. So here they are. As you can see, we got rid of the lower bracket mount.
jtsmith can the tire carrier bar be used for that ( support in that area) with the latch mechanism latched?[/QUOTE said:Yes, and their will also be two other item's added that will help out. I want to wait on mentioning those yet until it's finalize that we are going with them. There is also a third item that will help out with the tire removal that will come later. It's getting pretty close now in finishing it.(tire carrier that is) We just need to wait for part's to arrive.
Paul, is that 1`3/4" tube?
Yes!
Also any update on exspected finish date? I'm sure this recession has had a effect on your buissness too.
I was asking about the gate frame. Your using chromo for a gate though
I guess if that's what you got, at least will be strong
Perfect spot to make lunch off of on the trail.
What I really want to know is who is going to crawl under that tire and unbolt the studs? Or, if you wanted a fold down spare, why not just go off the rear bumper instead of making a swing out rack for it? Then, you could just fold down the tire to open the back hatch.
You should hook it up to the air system and have it go up and down with the push of a button.
