Been doing a little work on the weekend to the Ex but I've been too busy during the week to post up the pics and what I've done. Since classes ended yesterday and today is dead day before exams start I've got some time so here's what has been happening on the ex the past couple weeks.
First thing to report is a did a little work on the front end.
I started by cleaning the hubs as they were extremely greasy and from what I've read on here they work best when they are just lightly oiled.
I forgot to take a before pic but this was after I soaked them with some Awesome cleaner then washed them out with the hose. I then filled them with some cheap tranny fluid I had layin around. I also scrubbed the inside with a tooth brush.
Here's them pretty much finished.
I also noticed that the two hubs have different part part numbers.
I thought that these were same side to side?
But they also had different stickers on them. I just placed them on the side that they fit the best.
Here's what the spindle and brake stuff looked like.
I also figured while I had the chance I'd pain the dust shields. I went with some Ford Blue engine enamel I had layin around.
The pads need to be replaced but it looks like they'll be fine until after winter and the ball joints seemed alright too.
Last weekend I decided I was tired of using a screw driver to open the hood so I bent up a piece of 1/4" scrap I had layin around and used the angle grinder to round of the nose of it and cut it to size. I then used a 1/4" bolt to hold it to the original handle and now all you have to do is stick your hand under the hood and push up.
Here's a picture of it painted in white I covered the white with some more Ford Blue paint then bolted it up.
I didn't get a picture of it installed but I'll try to remember to this weekend.
This will probably be my last update till after Christmas as I have finals next week and as soon as I'm finished with them I'll be headed to Texas until the 23rd.
So I hope everyone has a great Christmas and don't forget the reason for the season.
