My pneumatic cut-off tool has seen better days, still works great, but makes a mess with flying metal debris.
I looked around for a temporary shield to help keep the sparks and airborne metal contained. I had an empty 2-liter Pepsi bottle that would work. I cut the top to match the mounting base size using the broken shield piece as a template.
Then cut the bottle at the top of the label.
Made another cut to allow access for the blade to do its work.
Voila, now time to start cutting. I started to cut the top of the firewall that started at the windshield mounting surface that is attached to the top panel that needs to be removed.
Once cut, I pulled the panel back to take a look at the once-hidden area. I haven't cut any more in this area yet, because I need to get more and better measurements of the 56 firewall to compare.
So, it was time to prepare for the cab. I cleaned, organized and got things in order for this next exciting step. I got my brother, brother-in-law, and a co-worker friend to come over to help. As much as I've done by myself, moving the cab was not something I wanted to chance with less than 8 hands. I did stand the bed on its end in the corner of my shop to get it out of the way by myself, that was fun.
I prepared the cab by removing the windshield and rear glass to reduce the weight. It was lightly raining, so I didn't get pics of that process. Cutting the inside rubber gasket of the windshield was the best way to remove it without damaging the glass or the chrome trim around it.
The rear glass was already busted so it was not so much concern. In fact, it was actually harder to remove that piece than the front! Once the cab was ready, I spent some early morning hours cleaning up the motor even more. Oven cleaner and purple power cleaner was used again here.
Sunday morning, found my son working on his own project, lol.
Got everyone over to move the cab, my brother tried to drive it in
Notice the Mercedes in the background, that was one of the ones I sold a month ago.... still in my yard.
We decided to pull the frame out of the shop to set the cab on top to clear the low doorway, fan and other obstructions.
Not centered or in place by any means, but we got it back into the shop easily as it was much lighter all stripped down like I have it.
And then the kids thought it was a great trampoline or dance floor.... not sure.
Although the frame width is approx 40-1/2" wide and the cab has a 41" gap, I wanted to get it in a way that I could easily move it without requiring help. Using landscape timbers, it provided a perfect setup.
I can almost imagine it now!!!
Getting sleepy. Next time, I will post engine progress. New oil pump, pan gasket, and paint!!!
