Spudhut
US Navy Submariner
- August 14, 2017
- Location
- NW Arkansas
- Bentonville, AR
- 1997 Explorer Sport - 4x4
- Callsign
- KG5SPB
Quick photos of bolt locations to remove grill supports on both Mountaineer and Explorer. The Red and Yellow are locations for the support removal - Blue is to remove headlights via clips on the back side...save the spring clips; after the support is off the vehicle.
The top grill plastic cover/access panel and turn signal lenses are easy to remove - Im guessing most everyone should know this procedure.
Wiring can be tucked back into body area. I cut off a few of the connectors just in case for turn signal lenses from mountaineer to use on Explorer.
The Lower Red Arrow on Photo #1 is the hardest to get to. You have to get behind the plastic wheel well cover to get to it with a long extension. I believe the nut is a 7/16"
Photo #1
Photo #2
Photo #1
Photo #2
to the interior...can be very time consuming...each french seam is made up of 3 stitches.
