1997 Ford Explorer - V8 - 5.0 - AWD | Page 13 | Ford Explorer Forums
Quick photos of bolt locations to remove grill supports on both Mountaineer and Explorer. The Red and Yellow are locations for the support removal - Blue is to remove headlights via clips on the back side...save the spring clips; after the support is off the vehicle.
The top grill plastic cover/access panel and turn signal lenses are easy to remove - Im guessing most everyone should know this procedure.
Wiring can be tucked back into body area. I cut off a few of the connectors just in case for turn signal lenses from mountaineer to use on Explorer.
The Lower Red Arrow on Photo #1 is the hardest to get to. You have to get behind the plastic wheel well cover to get to it with a long extension. I believe the nut is a 7/16"
Photo #1
index.php
Photo #2
index.php
Awesome Info thank you sir. I am going to be doing this Modification on mine also.
Went to JY on Saturday, found this Flowmaster under a custom painted Mountaineer that I have been picking from. Didnt think to look under it. $10...:)
Got it home and welded it in!
index.php
I finally got all the brakes done. Fronts and rear calipers are rebuilt. New Pads and disks on the front and rears were good for now till I replace them w/ new units. Still contemplating the Ranger upgrade...
Im all about just getting this on the road at this point.
I decided to drive it around the block till I realized the front diff rear gear was shot...all the grinding and clunking of bad teeth. :) I ordered a new pinon and ring gear months ago, I guess I better get it in!
Here she is on the street for the first time. Its a great feeling to know its 'running and driving' again. The rear sags a little, I may put some warrior shackles back there to push it up a little.
Still have to put in new shocks and Im contemplating on hooking up sway bars for front and rear w/ quick disconnects.
With the new year coming, I'm contemplating tire size. I unfortunately stuck with 3.74's for the ring gears, should have went 4.11's. So, I may keep the 33's for now even though I would like to stab 35's under her. Any thought's on this?
index.php
index.php
index.php
Some fun photos; a little flex... No creaking or popping
I know...rediculous, but I had to show off to the other 2 Gen 2's in the driveway who was boss!
index.php
index.php
index.php
Jeep wheels!!!!
NOOOOOOOOO!!!!
Kidding Merry Christmas looks awesome! I love a SAS Gen II
Looking great!!!
Awesome find on the muffler. How loud is it? or just a mellow rumble?
With the lift you have i would go 35's , I would sell the 3.73's and go with 4.88's just my two cents.:)
I was originally going to do 33's until i went to buy the tires and saw the ridiculous price difference. The 4.56 gears do fine with the 35's but if i am towing a light trailer it will kick out of overdrive or drop speed with a good head wind or grade. it's not terrible but annoying on long trips. I would have done the deeper gears if i knew i was going to wind up with 35's
@johnny499 - its a nice deep rumble, not annoying like a single baffle unit. It enhances the v8 nicely. Its currently cut off right behind the rear seat, still not too loud. I will add some tips to dump it downward and see how it goes. Thank you on the feedback for the ring gear, makes perfect sense.
@410Fortune - Easy...these are temporary :) ...new rims and skids will be in order during tax time! :)
Noticed a pictures in the beginning were missing - I replaced them to keep this thread 100%
I added "FIX" to temperature gauge issue I was having:
Since getting all the hoses reconnected, checked for leaks, I have been able to fire it up and warm up the engine and make sure items like the trans is full since all the swaps I have done. Everything is working well.
Since I have been able to warm this up, I noticed since replacing the thermostat...(click this link)
...the temp gauge is now working!!!
Any tips on replacing the thermostat? I'm doing the job as soon as my parts come in. Seems straight forward and not much different than my Mustang 5.0. Does the fan need to come off?
You don't have to remove the fan, but you will have to remove the hoses. There are 2 connected. Its an easy swap out, just take your time :)
WOW I just looked at the first pictures and WOW What a change from the time you got her to now.
Worked on some upholstery ideas and vinyl textures I had on hand. Center arm rest is a charcoal black with a grey French seams along the sides back to the rear vent panel cover...I’ll follow down to the cup holder too.
What you think...I plan on accenting the interior (door panel covers and door arm rests the same way) with the French seams, in grey... The vinyl is a high end textured boat material that is super durable.
This is right after I finished...I still need to add some steam to get the wrinkles and bumps out.
That looks damn good!
geeesh mr upholstery that's awesome
What did you use to make the stitches? did you make a pattern/template?
Also don't miss the January blowout sale!! I got my 25% off coupon today!! LMFAO at HF everything is ALWAYS on sale..........
I have an old Chandler Industrial Upholstery Machine (1970's Japanese made).
I 'draw' out the design I would like, then patterns are cut out, then sewn together. I like the 'french seams' allot, adds a little 'Lux' :smokin: to the interior...can be very time consuming...each french seam is made up of 3 stitches.
Can be fun ... sometimes o_O
Worth it
Wish we were neighbors, I could use those skills and that tool!
Impressive is an understatement, best looking Gen II console ever!
