allmyEXes
- February 6, 2016
- No. Alabama USA
- 1997 Blue Ex 4.0 SOHC
- Callsign
- KAGG 3611 (CB)
Yes pleasethere is a guy in Ocala Florida that deleted my PATS in my 1999 3.0 PCM. I'll try to find contact info if you want it..
I don’t have any cats so I was planning on running true duals with mufflers.I still have the v6 cats but I feel like they will be restrictive for the v8Deleting cats is illegal. You'll have a hard time getting that done for you, as now there are 2 people breaking laws.
Keep front cats, and upstream O2 sensors .
Since you don't live where someone will check the cats, when you have the exhaust made, get a universal cat or 2. Dyno tests have proven they don't kill power.I don’t have any cats so I was planning on running true duals with mufflers.I still have the v6 cats but I feel like they will be restrictive for the v8
Hey does anyone know what radiator would work for the 5.0 with the manual transmittion being I don’t need the trans cooler lines like the automatic transSince you don't live where someone will check the cats, when you have the exhaust made, get a universal cat or 2. Dyno tests have proven they don't kill power.
Cap the trans cooler ports.Hey does anyone know what radiator would work for the 5.0 with the manual transmittion being I don’t need the trans cooler lines like the automatic trans
Get a 1997 V8 explorer AWD. Radiator at AutoZone. Lifetime warranty by phone number , they usually stock emHey does anyone know what radiator would work for the 5.0 with the manual transmittion being I don’t need the trans cooler lines like the automatic trans
If you'd read the thread, he's way beyond that point of no return.I would pull the heads before making a final diagnosis. You have to pull the plenum and exhaust manifolds to pull the motor so you're almost there. A 5.0 is nice but first you have to find one. Mustangs got first dibs and junkyards are starting to crush the old Explorers.
I have been there. Your Head Gaskets, one or maybe BOTH of them are BLOWN. It will NOT fix itself. If you OVERHEAT like I did, the 4.0 Liter Engine is NOT rebuildable. Once it warps it's toast. (Cannot be "milled".) Been there Done that and now have a 2010 G2. Had to call the salvage yard to haul away my beloved 2005 G1 at 230,000 miles.Hey guys I got off of work today and drove home when I got home I was adding windshield washer fluid and noticed my coolant resavoir was completely full and had over flowed everywhere,I checked the radiator and it was empty so I added coolant and started it back up.I noticed a cloud of white smoke that smelt sweet took the truck for a drive and at idle it putts and feels like it’s misfiring when I got home I turned it off and tryed to restart it and got a click so I pop started it and it started idling again but putting is my motor blown?and what should I do next I have about 10k into this truck already(1999 4.0 ohv 5speed 4x4 4door)
You hydraulically locked the engine. A cylinder filled with coolant. Pop starting likely destroyed a piston & rod on the hydrolocked cylinder.It starts after pop starting but runs like garbage thank you for all the help
Not sure you can work a forum . Read the threadYou hydraulically locked the engine. A cylinder filled with coolant. Pop starting likely destroyed a piston & rod on the hydrolocked cylinder.
The engine is junk.
I'm not sure if you have the mechanical knowledge to do the 5.0 swap. Best to get someone who has experience to do it.
Astrobuf
Hey everyone I haven’t posted in here in awhile so I thought I would update everyone.I got the 5.0 motor in and very close to getting it started.I ordered a computer off of eBay with pats and manual trans deleted for the 5.0 so I lucked out with that.the engine bay is almost complete I’m just waiting on a radiator and a fan and some small stuff like oil and oil filter.I got almost all the parts for the trans,I’m thinking I’m going to have to go to the dealer and get some fly wheel bolts and exaust manifold bolts because I can’t find them anywhere.I just wanted to thank all of you for showing support because almost everyone I know just keeps saying why are you fixing that pos,it’s an exploder,it’s not worth it but I keep pushing through because I know when it’s done it’s going to be bad ass and way better than a squated TahoeOh how I love a 5.0+M5R2+4x4 swap!
@Ruben9237 you're clearly passionate about your Explorer, dedicated enough to source the right donor vehicles, and (most importantly) motivated to learn the mechanical skills as you go -- don't let any naysayers convince you otherwise.
When I was your age, all I could do was change oil, rotate tires, and check fluids! Patience and persistence will get you where you need to go and there's a wealth of knowledge in old posts (best ones already shared in this thread) and in the minds of active members on this forum. Best of luck to you, I'm excited to see you pull this off.
