Explorer Audio upgrade(s)
mwoods269
Baltimore, MD
2013 Limited
Car audio shop told me the sony must stay as there is "communication from HU to sony" hopefully not but hooefully not. Still researching as I would like to get rid of that crappy sony as well. Maybe that pos has gain controls on it?
richardacushing
WA
2012 xlt
This is what I am thinking and I don't have the Sony system but that really should not matter. There are 3 separate parts to the audio system. 1. the MFT unit. 2. the CD/radio unit (Sony branded or Ford branded) and 3. the amp.
The MFT and the CD/radio unit are not one piece but are joined together with cables and communicate with each other. This way Ford can make the MFT independent of the type of CD/radio that is used. But, the CD/radio must be either the Sony type or the Ford branded type for the system to work. The amp on the other hand doesn't really matter since it would only be working with the CD/radio unit and is only receiving audio signals from the CD/radio.
Am I understanding this correctly?
richardacushing
WA
2012 xlt
I took a look at the factory amp. I have the non-Sony 8 speaker.
The vehicle has 7 wires entering the amp.
1. Solid yellow (RF -)
2. Solid purple (RF +)
3. Purple w/red stripe (Amp turn on)
4. Solid green (LF +)
5. Solid gray (LF -)
6. Gray w/red stripe (12 volt radio ?)
7. Black w/yellow stripe (unknown)(ground ?)
The vehicle also has 4 wires exiting the amp.
1. Solid white (LF +)
2. White w/brown stripe (LF -)
3. White w/orange stripe (RF -)
4. White w/purple stripe (RF +)
Does anyone know what these wires represent? And how can 4 wires leaving the amp power all of the speakers?
Edit
Added some of the wire functions. http://www.the12volt.com/installbay/forum_posts.asp~TID~125888
7. I am just guessing.
Also added photo
machine4321
Ontario
2017 sport
The amount of wires, in or out, does not make sense. I could see 4 pairs of wires being the input. It is likely the non sony system starts out as a simple fron L+R and rear L+R. The out on the amp should have at least 2 pair for the front doors (thats a minimum assuming the crossover network is located in the door to seperate the tweeters and woofer). A pair for the center, the rear could have some tricky wiring as the rear fader only controlls the"rears" (that would include the rear doors and 3rd row speakes). If they are wired in series than the amplifer may only have 2 pairs of wires for all 4 rears.
I cant see that happening as the wiring is much easier if it all gets home run back to the amp. This also gives them the abillity to set the levels and individual crossover points( 3rd row speakers dont produce much, if any bass. They are just for fill.
richardacushing
WA
2012 xlt
I was looking at this: http://www.the12volt.com/installbay/forum_posts.asp~TID~125888
I was thinking that maybe the CD/radio has an internal amp that handles the audio for the rear speakers. The amp in the rear would handle the front speakers. When someone uses the Sync functions the MFT unit tells the CD/radio to shut off all audio to the rear speakers, then the amp is used to send the Sync audio to the front speakers only.
Could this be the way it is setup?
richardacushing
WA
2012 xlt
I am also wondering, in the 8 speaker non-Sony system, if the 3rd row set of speakers preform the same function as the front row tweeters. Are they in a two-way configuration with the 2nd row speakers?
deewan
Cedar Rapids, IA
2012 Explorer Limited
There does seem to be something goofy going on. It is possible the head unit has an amp built in to power the center channel. And that could make sense because the wiring wouldn't have to be any longer than a few feet and unless you turn on the 5.1 sound (Sony system only I think) the amp in the head unit would only be on when MFT is used.
It is also possible the third row speakers are run in parallel with the second row door speakers. If the speakers are 8-ohm each that would present a 4-ohm load to the amp. However, if other posts are true, the second row door speakers are 4 ohm and the third row are 16 ohm. So I'm not really sure what is going on there. Although it still could be done.
To clear up some items:
  • As far as the Sony system and what I experience. When MFT is in use, audio is not shut off to all the rear speakers, it is muted a certain db level.
  • According to the 12-volt wiring log, the amp for any speaker is located in the rear quarter panel. However, this may only be true for the Sony system.
  • I have a feeling the picture you included a few posts ago is that of the outputs from the amp. And the input/output labels you included are reversed. The reason I believe that to be the case is based off the number of wires.
An easy way to determine what wires are doing what, take a look at one of the speaker terminals. If the wires going to the speaker are white with a striped color, then your labeling is correct. But if the wires to the speaker are solid colors, then your input/output labels are reversed.
JohnCue
Fort Lauderdale, FL
2013 Ford Explorer XLT
Thanks deewan.
I plan on replacing the stock speakers (all but may leave center channel), adding an amp for the new speakers and adding a sub and an amp for it. I am thinking of going with Memphis http://www.memphiscaraudio.com/products/speakers/
Of course, I am assuming the stock radio will accept these additions. LoL.
deewan
Cedar Rapids, IA
JohnCue - I have seen the Memphis product at my local shop. They look like a solid product. Will you be doing the work yourself or having a shop do the work for you?
mwoods269
Baltimore, MD
2013 Limited
I counted my 2013 sony sound speakers and only count 10 (2 front tweeters, 2 front doors, 2 second row doors, 2 3rd row head tweeters, sub, center speaker)
deewan
Cedar Rapids, IA
Sony counts the 2-way coax speakers in the second row doors as 4 speakers (one woofer in each door and one tweeter in each door x 2 = 4). Technically they are correct, but it's a gray area.
mwoods269
Baltimore, MD
2013 Limited
what that mean I can pull full Range from the second row doors to line level converter to an amplifier?
machine4321
Ontario
2017 sport
Do not pull high level from the rear or any doors. There is a lot going on with factory signals these days. They never are full range. usually cutting out subsonic (usless low freq that smaller speakers cant use). These are important freq for a sub system. If you have noticed the bass performance is different all through the volume range. As volume increases bass output levels roll off to improve over all loudness.
Take the high level off the sub. its the best you can get with out an aftermarket HU.
JohnCue
Fort Lauderdale, FL
deewan, I'll have the shop do it. I know great audio quality and know when to keep my hands out of trying to install it. LoL
If you like EDM (Electronic Dance Music), this is me: www.emotionradio.com
Take care,
John
deewan
Cedar Rapids, IA
I think what mwoods meant, and machine4321 suggested/confirmed, you do not want to take a signal after the OEM amp. You want to splice into it before the OEM amp. Even then, the head unit is probably doing some EQ'ing at certain volumes. But for those who do not have a factory sub, if you splice into the signal for the rear speakers BEFORE the amp, that is your best bet (outside of replacing the head unit).
Take care,
John
John, feel free to report back on your install and your listening impressions. Thanks for the music link. I listen to everything and always interested in new music.
machine4321
Ontario
2017 sport
Do we know if the signal before the amp is classified as a lowlevel? Taking signal from before the amp and running to the highlevel filter may not work out so well. not 100%, just thinking out loud.
JohnCue
Fort Lauderdale, FL
Not a problem. Will do.
hmsracing
florida
Edit
Also added photo
Hello there to all....
I am new to the forum and own a 2013 Explorer XLT with 9 speaker premium audio. I was expecting to find an amplifier behind rear quarter panel but when I pulled the panel there was no amplifier. I understand that the Sony premium in the limited has the amplifier but I thought the premium 9 speaker would also have it...I see there is a pic of the Amplifier for the non Sony 8 speaker but where did you find that? I am looking to add JBL ms-8 and a pioneer shallow subwoofer in a custom fiberglass molded enclosure behind the rear panel with cone being at the opening where the OEM sub usually is and where my current cubby cover is...
I need to know if there is a factory amp with this system and where and if not can I tap into harness at head unit for ms-8? MFT may be an issue...
hmsracing
florida
So, I'm wondering, is there an amp at all with xlt with 9 speaker premium audio? I would think that if it did have an amp that it would have been in same location as Sony but as noted in prior post I did not find one. So is there another location?(center console, in dash?) Or is integrated into head unit?
After searching forum I have not found anyone who has noted finding xlt premium amp or adding processors or amps to mft....
Anyone?
13Sport
Los Angeles, CA
2015 Explorer Sport
Anyone?
XLT 9 speaker premium does use amp. Same location.. passenger side rear quarter panel (basically even w/ the 3rd row seats on the passenger side behind the plastic)
J 2014 Explorer Audio Modification. Modified 2011- 2019 Explorers - Tuning & Mods 1
E 2019 Explorer XLT Audio Modified 2011- 2019 Explorers - Tuning & Mods 1
L 2016 Explorer Sport - Audio System Build Modified 2011- 2019 Explorers - Tuning & Mods 60
L 2014 Explorer Sport Audio Idea Modified 2011- 2019 Explorers - Tuning & Mods 6
M Can I use 18" wheels on my 2017 explorer limited. Modified 2011- 2019 Explorers - Tuning & Mods 2
R Steeda springs (555 8202) vs Sport explorer springs (DB5Z-5310-K) in my XLT with B6 install Modified 2011- 2019 Explorers - Tuning & Mods 5
A New Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 1
O 2016 Explorer sport Modified 2011- 2019 Explorers - Tuning & Mods 3
Bobs2018Explorer Is it possible to recalibrate the Explorer transmission to the same settings as the PIU transmission? Modified 2011- 2019 Explorers - Tuning & Mods 10
X Explorer Front Stock Speaker Upgrade - Sony System Modified 2011- 2019 Explorers - Tuning & Mods 6
R Best hubcentric spacers for a 2019 Explorer? Modified 2011- 2019 Explorers - Tuning & Mods 2
W 2016 Explorer Limited - 911 Assist Not Operational Modified 2011- 2019 Explorers - Tuning & Mods 6
S Mods for wife's 2014 Explorer Modified 2011- 2019 Explorers - Tuning & Mods 2
Fasterdamnit! Help! Power Stop Z23-1508 pads do not fit my '14 Explorer Sport front calipers Modified 2011- 2019 Explorers - Tuning & Mods 10
S Raptor Grille for Ford Explorer 2011-2015 Modified 2011- 2019 Explorers - Tuning & Mods 14
C 2019 Explorer Sport Speaker Install/Discussion Modified 2011- 2019 Explorers - Tuning & Mods 1
ecoboost_xsport 2015 Ford Explorer Stock Speaker Upgrade - Sony System Modified 2011- 2019 Explorers - Tuning & Mods 20
L 18 mustang wheels on 17 explorer Modified 2011- 2019 Explorers - Tuning & Mods 4
J Hide wooden trim in explorer? Modified 2011- 2019 Explorers - Tuning & Mods 2
J Tow/Haul Mode 2011 Explorer without tow package Modified 2011- 2019 Explorers - Tuning & Mods 3
G Installation of Power running boards on my ford explorer 2015 XLT Modified 2011- 2019 Explorers - Tuning & Mods 4
TJ@Steeda Steeda New Product Release: Steeda F-150/Explorer Pro-Flow Blow-Off Valve Adapter (2011-2019) Modified 2011- 2019 Explorers - Tuning & Mods 1
C Explorer sport 9006/9012 upgrade Modified 2011- 2019 Explorers - Tuning & Mods 2
J Issues with FORScan in 2018 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 21
TJ@Steeda Now Available: Steeda Explorer Adjustable Toe Links Modified 2011- 2019 Explorers - Tuning & Mods 10
M Headlight/Fog light upgrade for 2015 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 24
M 2018 Explorer Speaker Install Modified 2011- 2019 Explorers - Tuning & Mods 49
9 2016 Explorer Sport Downpipes or Borla Catback Modified 2011- 2019 Explorers - Tuning & Mods 2
expoman55 2019 and 2020 Explorer wheel pattern & tire size. Modified 2011- 2019 Explorers - Tuning & Mods 2
J Upgrades for 2018 Explorer XLT Base? Modified 2011- 2019 Explorers - Tuning & Mods 1
J How to "Sportify"/black out my non sport explorer? Modified 2011- 2019 Explorers - Tuning & Mods 4
D New Explorer owner ready to modify Modified 2011- 2019 Explorers - Tuning & Mods 2
G 2015 ford explorer XLT Door Unlock Wire Modified 2011- 2019 Explorers - Tuning & Mods 2
B Any more upgrades to a 14 NA Explorer? Modified 2011- 2019 Explorers - Tuning & Mods 1
F 2019 Explorer Sport thermostat change Modified 2011- 2019 Explorers - Tuning & Mods 2
Z Setina PB 400 Push Bar installation help 2012 Explorer Modified 2011- 2019 Explorers - Tuning & Mods 3
C Any of the PIU front bumper components fit base Explorer? Modified 2011- 2019 Explorers - Tuning & Mods 1
S Need Help - Explorer Not Shifting Up When Floored - Bigger Tires 295 45 20 and SCT Tune Modified 2011- 2019 Explorers - Tuning & Mods 5
T Lincoln Navigator 22’s on Explorer Modified 2011- 2019 Explorers - Tuning & Mods 6
T Mounting gun box (security box) to 2014 explorer sport (floor mount) Modified 2011- 2019 Explorers - Tuning & Mods 1
ghosted Some good, but mostly hilarious Explorer mods Modified 2011- 2019 Explorers - Tuning & Mods 10
F Borla Cat-back install on my 2014 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 14
J 17 explorer cargo/trunk light bulb type? Modified 2011- 2019 Explorers - Tuning & Mods 4
1 Best tuner for Explorer Sport? Modified 2011- 2019 Explorers - Tuning & Mods 32
A Comparing LED bulb to my old Halogen bulb - Explorer 2013 Modified 2011- 2019 Explorers - Tuning & Mods 14
expoman55 360 camera view available on Explorer? Modified 2011- 2019 Explorers - Tuning & Mods 4
M Ford Explorer Dyno Tips Help Modified 2011- 2019 Explorers - Tuning & Mods 2
B How To: 2017 Explorer Custom Mount for Yakima Awning Modified 2011- 2019 Explorers - Tuning & Mods 6
B 2018 Explorer SPORT tune and exhaust? Modified 2011- 2019 Explorers - Tuning & Mods 19
D 2013 Ford Explorer Sport “Recommended” upgrades Modified 2011- 2019 Explorers - Tuning & Mods 4
Similar threads
