Byrd91
- December 3, 1999
- Penobscot, Maine
- '92 XLT
Kirby is totally right on this one. A 4 link or dual radius arm setup (on solid, not TTB) has bind built into the suspension. A 3 link like redranger posted or JoshC posted (well 1 radius arm and 1 link is basically a 3 link) is ideal because 1 side controls the arc of the axle while the other is just a long for the ride and holding the axle laterally. You get to 2 radius arms or 4 links and stuff one side and droop the other its trying to twist the axle in half = binding = not good flex. 3 link or radius arm then depends on preference and what type of front driveshaft you have...single u-joint goes naturally with 3 link (axle stays parallel with outputshaft) and double cardain or CV goes with radius arm (axle rotates to point at outputshaft).
Yomie, are you going to run with no trac bar? Otherwise whats the advantage of your setup?
