- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Basic physics: Mustangs that weigh 3500 pounds or so have different needs than a 4700+ pound Explorer.
Explorers(AWD) can take all the bottom end torque that you can make.
Mustangs are already spinning their tires with stock power.
The needed power bands are different. You should be trying to raise your power band. It would not be smart for an Explorer owner to soften the bottom end to gain top end. The stock exhaust is just fine in the Explorers for most people. You can spend $1000+ on the whole exhaust, and maybe gain 20-25HP. That's a ton of money for little gain. There are better ways to make more power.
If anyone wants a different sound, then they should change the muffler.
SECTION is planning to change to a supercharger. If it is the EE version, then it's only going to add about 80HP. He won't need a huge exhaust, bigger yes, but not huge. The equivalent of dual 2.5" pipes would be more than enough.
The PCM in the 2nd gen Explorers is better than the 94-95 Mustangs. It was designed later, for use with the distributorless system. If SECTIONS PCM is functioning properly, than there is no need to change it, upgrade it, or tweek it. The chips are designed to compensate for parts that are out of the normal parameters. His A/F ratio is way too lean, that points to the chip or the fuel system, assuming that everything else is okay.
This thead was about aftermarket headers for the Explorer. The BOTTOM line is that they have only 1.5" primaries, and they are extremely expensive. These headers would be fine for a stock 302, but anything bigger or more efficient needs bigger pipes.
Those people should use these 1.5" headers as prototypes, and build a set with 1.625" primaries. If you check around, you will find that the vast majority of headers for a 302 have 1.625" pipes, with a lot even larger.
Calm down, and think about what you say. Novices may take your words as gospel and apply them to other applications. Long tubes are much better than short tubes, when applied correctly.
CDW
CDW
