- August 1, 2008
- MO MO
- 94 & 95 XLT's
If you have been following this thread for the last month, you know I have been making something for this, finished it, but couldn't install it alone.
There was a couple reasons Kurt visited this weekend, and this wasn't really the reason, but I'm so glad it became one. With his help and ideas, we got it installed by golly. Took us the rest of the day, including a parts run, and and grub breaks. It was a nasty foggy day. We got cold rain for the last hour of the job.
So this is the thing I made. It is a full size Roof basket, with a front light bar. Has built in brackets for the Hi-Lift jack, an Axe, Shovel, Max tracks, and a 270* awning. Made from 1" sq tube, 1" round tube, 1/8" plate, 1/8" expanded metal, A little bit of angles, some steel conduit, and a couple pcs of 16 ga sheet.
This thing is big. Like real big. It's a game changer for how I can pack, and what I can pack for trips. It has 4 times the interior Cubic Ft than the previous basket. Larger (but light) items can be hauled up there, freeing up inside space. It does not block the moonroof, and that is fully functional still. I wanted to keep my emergency exit. lol
It is wired up using electrical conduit that is hidden underneath the basket, and on the light bar. A waterproof 7 pin trailer junction box used for all wiring but the rear view camera. 2 front lights are on until I get a larger light bar to fill the space on the 1" round tube. 2 side lights are mounted with more 1" vertical round tube. Rear view flush mount pods are installed in the rear boxes, that also have AUX power via waterproof SAE plugins.
One of the hardest things with the old basket was loading & unloading it. I decided to make a hinged gate in the back for this. 1/8" plate with full tube framing under it, that is butted up to the expanded metal flooring goes between the boxes, and will be used to slide items into it. The gate has a beefy hing pin made for big steel BBQ smoker lids. It even has a grease zerk. To latch it, two locking clamps was welded on, and the catch's welded onto the side box. It's solid, and doesn't move a bit when closed.
It was primed with weld thru primer everywhere plate went over tube, and between the tube and expanded metal. the entire thing was primed with self etching after all welding was completed. The underside was coated with slow dry oil enamel, and the inside of the rear boxes was sprayed with oil. The top and sides was then coated with 2 coats of 2 part Urethane Raptor Liner. 1st coat was applied with the texture roller. The 2nd coat with a smooth roller. The rear boxes only got a smooth finish.
Ok, so back to the install. The idea for 2 of us to be able to get this thing on top of a rig that has a 7 foot top, without any carnage to it, was Redneck as you can get. BUT... it worked, so it was pure genius. Thanks Professor Kurt.
2"x6"x12' boards staked to the ground, laid on the roof side, and wrapped ends with foam and towels, was used to slide the rack up to the top, then slid across the roof into place. We sprayed the boards with dry lube made for RV window tracks. made a nice slick surface. 2"x4" was screwed to the 4 mount brackets, to slide along the 2"x6". I used 3/4"x 4"x 36" pcs of cutting board material on top of the roof, to slide the 2"x4" under the basket across the roof, and into place. Not a single scratch, no carnage, and a success.
Stainless T-Bolts was bought for it, but the first one snapped the T right off when tightening. Change of plans, and stainless Carriage bolts was used. We ground the round tops off, and made them flat. External toothed washers, with a stainless washer placed on them, and slid into the factory roof rail tracks. They are 5/16" x 1"L, and worked perfectly. No side to side slop and snug in the center of the track slot. 2 bolts per mount, 4 mounts, 8 bolts total. Mounts are welded and wrap the frame tube, offering 1.5" of lift for the rack.
Ok, so skipping all the build pics, and getting right to it, here is the boards placed on the rig to slide this thing on.
I know your laughing right now, but that's ok, LOL away!
Here it is all bolted up, with the awning installed.
Mock up with the hi lift, axe & shovel installed. I wont put these on until it's time for a trip, and store them indoors. The shovel is high, and out of the way of the moonroof glass when opened for vent.
I have pictures of the entire build, if anybody has any questions, let me know. I'm happy to answer any, with pics. I still have to run the power to the junction box, from the rig's console switch panel.
Yes I know it is big, and tall and it looks weird, but... once outfitted, and the trailer hitched up, it will look like it belongs. Hardcore crawling isn't this rigs intended use, and it is closer to it's real purpose now. I don't mind the higher COG with this. It's a trade off to be able to gear it the way I want.
Love or hate it, it has a purpose, and even I have to get used to it. I haven't warmed up to the look yet, and might take some time for that to happen. lol
