2003 Lariat Super Crew "Husker Larry" | Page 3 | Ford Explorer Forums - Serious Explorations
I have the crankshaft locating tool on the pin and key
Cams at close to 11 o'clock right (passenger side)
and 12 o'clock on left side
So, I locked the cams in
I think I can start taking the tensioners and chains apart now correct?
good lord. i have done 2 timing chains on 4L sohc's on the stand and that was no fun. your doing this in the engine bay thats just as stuff'd in there or even worse. i bow down to you
Looking good. Tbh I don't use any timing tools on the 5.4 myself anymore. If you have the keyway on the crank at 12:00, usually you can take the chains off without the cams flopping. Since you have the tools you don't have to worry though. Make sure you replace the oil filter housing gasket if you haven't already, major common leak point. Make sure you lay out the guides as they come off. The tensioner guides look the same but they arnt, they are side specific. I also hit the timing marks with paint marker, makes it easier to see then lining things up.
Engine does look really good on the inside, no sludge / barely any tarnish. I'm sure you'll find the tensioner gaskets blown but the chain guides are all there. Honestly I'd skip doing the oil pump(since you have to remove oil pan on the ground). Main reason you pull the pan is because the plastic debris will clog up the pickup tube. Your's looks all there, probably just blown out tensioners is all your hearing.
Good stuff, thanks! I really appreciate the advice and encouragement.
I have the Timing components out,
all good except the expected blown tensioners gaskets.
Ford is bad at timing components lol:)
Welp, I. Admit it. I bit off too much, gonna spit a bite back out. Valve seals are not gonna happen. On a stand maybe but not me, not under this hood.
Ok, pictures for your view. I think it's safe to pull the pins.
Additional picture of factory reluctor wheel. Although I purchased a new one there is no need.
Looks all right to me. Pull the pins, rtv the corners and where the head and block meet.
Well, the valve covers cleaned up good but the timing cover looked bad after power wash.
Could not put it on like that so, it got coated. Casting is very rough, but it will wash off easier now when it does get dirty
Still waiting on the oil filter housing gasket as suggested above. Also went to dealership for a water pump and thermostat which they got in today.This truck still has factory water pump, 20 years and 143 k miles.
Pre lube that sucker
The 4.6/5.4 water pump is one of the stoutest factory water pumps
Half of the engine is behind the windshield also, the firewall steps way back.
Took me a while to get back. Looks like you've got it under control. Not a lot has changed since the 97 4.6 I worked on. The 97's still had steel tensioners and I think it had two gears for the timing chains on the crankshaft. (Newer ones were one piece) But still the same design. The Tbird was pretty cramped to work on in the bay as well. I did it both ways. The first time I was just installing new PI heads, the second time I was installing a replacement short-block so I was able to do a lot of the work on an engine stand.
Was 105 degrees today.
Got the pesky gasket changed, water pump and timing cover installed, removed thermostat and block plug for a good flush.
Also got the new valve cover bushings installed , and the help it's seated under the gaskets. 27 valve cover bolts
Ok, because of this picture
I lost all sleep last night and over an hour of wtf. Time wasted. Valve covers are still off, I cranked engine over by hand at least 10 times while mlb held her finger against cam lobes feeling for a chip.
That picture shows the front cam lobe with a chip out of the side.
It's a weird flash reflection from what I can tell. There is no chip. The line is fine?
Reflection, or, divine intervention? This is wierd
Looks weird in that picture for sure. I've probably got one lying around for comparison
It perfectly smooth, according to wife's finger, while rotating. It not even there
