Okay thanks to JTSmith I realized that I needed to adjust my camshaft position sensor to factory specs before I run this engine.
I ordered the necessary alignment tool and did the procedure this evening:
First I removed the serpentine belt, then the AC line from the canister and compressor (to get access to sensor).
Next I pulled 7 spark plugs, leaving the #1 cyl plug in place.
Then I removed the cam sensor by loosening the retainer and bolt.
Alignment tool & top of cam body with sensor removed:
To bring the engine to #1 Cylinder TDC I rotated the crankshaft pulley using a 15/16" socket and 1/2" drive (the engine rotates clockwise from drivers seat)
I felt for the only remaining compression stroke (with 7 plugs removed), this is when the #1 cylinder has both valves closed and the piston is traveling up.
I then removed the #1 plug.
I watched the piston in #1 go up to the top and then back down one more time, back up to the top and this is top dead center.
I did it this way because it is far more work to remove the valve cover at this stage.
Once I found TDC I installed the alignment tool into the top of the cam sensor and carefully installed the sensor.
The stator in the cam sensor is driven off the oil pump shaft gear, the stator shaft must mesh (just like installing a distributor)
Once the gears mesh the sensor body will slide down into the block, but it will rotate as it drops.
I moved it once or twice in order to match the mark I had made before removal on the block and sensor body when it is fully seated .(only part during this re-assembly I didn't clean!)
Here it is in final position with alignment tool removed:
Put everything back together and we are golden.
I removed the NGK Irridium plugs I had installed in this block when I was still driving the donor truck in favor of some Autolite double plat's:
Thanks to EF & JTSmith I likely avoided some catastrophic engine failure.....oh and always second guessing the procedure for each stage of the build helps!!!
HEY JT did I do it right? hahaha
