410Fortune - 96 5.0L XLT refurbish (making 1 great Ex from 2) | Page 27 | Ford Explorer Forums
basically all the vacuum wiring and electrical where it's supposed to be routed, and how the spark plug wires go. it's been so long since i yanked the motor, i forgot where it all goes.
I had no idea where it went when I did the 5.0L in my BII (before I built the 96)!!
I found vacuum diagrams and pictures on this forum, I believe much of the info is in my BII conversion thread..
its pretty simple under the hood of the Explorer, but I can help for sure.... hell I have it memorized by now I dont even have to go look at the truck! I need to remove my upper intake again soon, I have new pushrods and lifters that need to be installed under my roller rockers.....
I also got some 5.0L Cobra valve covers.... oh baby those will clear the rollers and look slick, help with my oil fill tube location too...
The Explorer luckily doesnt need much work right now, she just goes and goes. I picked up a new trans mount for it (stock is history, $18 napa) and the steering shaft needs to be modified to clear my headers...new pushrods and lifters and shes good to go until I can afford paint! (or sport trac front clip LOL)
I pulled snow mobiles all over the state of CO through some crazy white out blizzards and through 2-3' of snow drifted parking lots all winter (Dec- April). She never asked for anything and has proven VERY reliable and still turns heads. 12,000 with 3000# of snowmobile trailer in 4 low trying to make it to the trail head is no joke! I wonder if Ford ever thought a Gen II ex would be doing such things :) LOL
Likely 17-18" rims some day, I'll stick with 33" tires for my daily driver / tow monster :)
I also have a spare GT40P 5.0L and 4r70w trans, I am itching to rebuild my own engine and trans.... question is which truck gets the 331 or 347 and built 4r70w? Explorer or BII????
Still dreaming of reducing the body lift to 2" and going with a Dixon/Deaver suspension
Tube bender is coming someday soon, already aquired chop saw and mig welder... after that its on like Donkey Kong (bumpers, sliders, etc)
went to turn key today and heard a hissing from one of my passenger side back injectors :(
looks like it's back to square one for me....
if you wouldn't mind checking your pm's I'd appreciate it there 410.
another thing I noticed..I bought this mountaineer with a hydrolocked motor and when I hooked the battery up today, I could hear one of the relays by the battery box in the fenderwell area clicking every other second or so...does that mean i have a short or that the relay is bad?
how do you find these deals?! 900 dollars for a decent ex. i wish i could find that around here. lol.
Blacksheep, actually the deal was found by mu buddy Brett right here on this forum.
$900 got me a 96 V8 with no fan, no trans cooler, a new radiator, two deployed airbags, a slipping transmission, a wrecked front end, beat up undercarriage, and a tired 5.0L
It did have a 3" body lift, some worn 33" mudders, and a whole lot of rock rash underneath! It took alot of work and $$$ to get her to where she sits today.
Yes it was still a fantastic deal, but $900 is about all it was worth sadly...
I find deals like this on Craigslist
We have less then $2000 in James 97 XLT, that truck was a good deal!! They are out there!!
thanks for the link, chrome is not what I want and I saw that! I cruise CL every day LOL, like I need more junk!
Yesterday 06/19 I crushed the old 96 truck finally... pretty sure my neighbors were sick of looking at thet SOB on top of the flatbed on the side of the house with seats sticking out the windows... she weighed just over 2000# with what was left of the body and interior, I got paid $190... not bad considering I paid $500 for the truck! LOL
RIP
Her spirit lives on in my other 96 Ex (drivetrain and more), also in James 97 Ex (wheels and tires) My "new" 96 is now going under the knife again:
new trans mount
new valve covers (cobra stang)
new pushrods
new lifters
copper header gaskets
new rear leafs (from crushed truck)
later this summer she'll need new tires, this Explorer has been VERY good to me, it runs like a dream every single day with no maintenece and alot of abuse
Now that the BII is fixed and out of the garage, the explorer is going in.....
explorer has been getting some goodies
I need to get the ol 96 into perfect working order, get rid of the final bugs I have been avoiding for a bit.
I want to be able to drive her ALOT in the next 6 months as I build the Bronco
I couldnt resist the new projector headlights
I LOVE the look of the black side markers and lamps I had previously, but the light output was sketchy. I planned to mod them into projectors someday and then BLAM! Aftermarket to the rescue!
The install as seen:
http://www.explorerforum.com/forums/showthread.php?t=231239&page=4
full write up:
new lights arrive, 15# for shipping:
So I took them apart:
First remove old lights, side markers, grill
also remove all stock light adjusters:
I test fitted them to find my 97 Mercury Mounty header panel needed a bit of clearancing for a perfect fit, marked with sharpie:
Cut with round, flat files, small saw, and pliers, 10 min per side:
Pass side:
Now after some testing of the wiring and the new lights I decided to make a few changes.
I wanted the flat light bar (above the projector) to illuminate yellow and flash with the turn signal
So I installed some 194 yellow marker bulbs:
and I made the following wiring changes:
This is the stock (truck side) light socket for the top turn signal
It attaches to the new light here:
yellow bulbs go here:
Now to cut the wires:
brown CUT WIRE from truck now becomes power for halo's (parking lamp 12V+ feed)
1. Green from new light wired to brown, truck side (now + for halo ballast, from above)
2. Black from new light tapped into black ground (- for halo ballast, from above)
3. brown power feed to new yellow bulbs tapped into white/green (signal flasher from truck)
---ONLY DO #3 if you want your flat bar to be a turn signal not parking lamp as intended from manufacturer---
now to fit the light
Wires route in prep for light (for best fit), ballsts go through the holes the wires are coming from
light wired in prep for fitting:
Note bluew socket on top right, red and black wires get pushed into the light and tan colored plastic fitting is twisted into the housing
turn signal bulb also gets pressed and turned into housing
not pictured, not lots of room to work here
NOW the grill goes on, it is not easy to get the lights through the grill and grill around lights, very carefully here:
Then the lights go in, press in 3 places like factory side marker and two top screws hold them in place
grill installed
ballast is hung, I dont trust 2 sided tape behind the grill for long:
I removed the battery and also zip tied the other ballast in place as well as loose wiring
installed!
Oops fitment issue with grill:
the humps on top of the new lights dont clear:
cut some plastic away with air grinder, careful here:
Perfect fitment, I am impressed with the engineering in these new lights ($$$$$$$):
Bulbs are Sylvania Extra Vision, high and low beams (h3 and H1)
LIGHTS HAVE NOT BEEN AIMED yet
Lows:
Highs:
halo's:
Video of the functions, note the yellow bulbs were not installed yet here:
http://fortuneelevatorconsultants.com/XLT/lights/xltlights.wmv
Great Writeup! Do you think the light output is better then the stock housing, and the aftermarket clear housings?
Nice work.
Lookin spiffy, nice Ford badge in place of the Mounty one:p:
Wow, excellent work and dedication! I wish I had your energy!
Mic my motivation is no car payment for 15+ years and I can build them the way Ford should have.
The light output far exceeds factory, clear, and the black diamond housings.
Next step would be HID of course... but I am very pleased with these lights they are quite a production LOL lots of lights going on......
truck is getting a steering column drop
(yes thats right drop, to help with steering agles due to the body lift
new (junk yard) intermediate shaft and remand rack and pinion today...
also doing drivers side tm header copper gasket (did passenger months ago) and 8 new spark plugs
Cant wait to drive her to the car wash, shes almost 100% mechanically and ready for paint :)
started this thread 4 years ago now! WOW
What are your plans for paint?
I know how to aim headlights, but how do you aim these aftermarket ones?
this color
