97Sandbox
- February 7, 2019
- Seward, NE
- 2000 Explorer Sport
Some may know that I resurrected a set of rusted Torque Monsters which I now have on my Mounty. They had rust holes at in the area where the primaries all come together and merge into the collector, so I set out to fix that.
The TMHs did not initially look that bad, but after pressurizing the headers (using tape and a shop vac in the blow configuration) and spraying soapy water around the collectors, I realized there were a lot of holes. So I carefully hacksawed off the collectors, and media blasted off the rust.
Then I sloppily MIG welded up the holes.
And ground everything smooth again.
Then I had a coworker nicely TIG weld the collectors back on for me. Since I worked at a big plating shop at the time, I was able to get them electroless nickel plated and clear ceramic coated.
All of that worked great! But I no longer work at the plating shop (great for me, but I do miss getting parts plated). I stumbled upon another set of rusted out TMHs last weekend, and now I'm going to try to do another revival, but with more DIY means.
