- November 1, 2017
- Lebanon MO
- 93 Sport
I also ended up having to go the the wrecking yard and getting another Taurus 3.0L (not 3.8L) fan shroud as I had chopped up my original in an attempt to get it to clear the water pump (mechanical fan) snout.
Decided to take only 9mm or so off the radiator side of the shroud and trim the top and bottom to fit. I will get some pictures of the fan mounted when I get a chance.
Currently the low speed it set to a thermistor switch on/off probed between the fins, ran to a basic 5 pin relay. Terminal 87 to the thermistor switch and terminal 87A to a manual on/off switch on the dash. If for some reason the engine isnt staying cool enough on low, I simply flip the switch on the dash, then power from relay terminal 87 (to the thermistor switch) is removed and switched to 87A to the high speed side of the fan
. Fully automatic operation on low, with high speed override.
But the LS ECM has a high and low speed relay ground circuit from the factory. Relay has power at all times, and the ECM supplies the ground to trigger the relay.
