2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Intake leak
Air must be getting into the intake system somewhere in order for the engine to idle at 2K rpm.
Is the EGR tube connected or open at the elbow? The PCM is supposed to command the EGR valve closed at idle but the EGR vacuum regulator (EVR) may not be working. If you disconnect and plug the vacuum line to the EGR valve it should close unless its stuck open. Also, there should be a manifold vacuum connection to the EVR.
I'm not familiar with the V8 but my V6 has a vacuum line connected to the fuel vapor management valve. If you have one have you connected it?
Did you check the vacuum line to the power brake booster?
