2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
CMP sensor
Other forum member have stated that their 5.0L will start and run (although poorly) with a bad or incorrectly timed camshaft position sensor. The PCM doesn't know when to open the injector for each cylinder and so the spray may not occur when the intake valve is opening. The result is a "stale" fuel charge in the intake port when the valve opens. My Haynes manual states that if the sensor connector is disconnected there should be at least 10 volts between the connector and ground when the ignition switch is in Run but the engine is not running. With the fuel system disabled and the connector connected to the sensor there should be 5 volt pulses when the engine cranks. If the +10 volt test passed but the +5 volt pulse fails then check the sensor ground path. If the ground path is good then replace the sensor.
