- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
A birfield is not the same as a CV joint/axle
SkanlaxJMO said:he said it was bigger then a 10.25....so im geussing no.....btw i gave up long ago...maby an axle out of an f-550.......????
TarHeel085 said:so if it came out a 550 then it has a dana 50 front.
410Fortune said:A birfield is not the same as a CV joint/axle
Yomie said:Hahaha, this guessing game is hilarious.
I know I Know!!!
Yomie said:Yeah, i've been sitting here debating whether i should give hints or not. I don't know when Jey wants to tell them.
Its gonna be a while untill they go under his truck. The gears for the front axle won't be out untill May or so (according to Randy's R&P) and no Lockers have been introduced for the rear yet....
oops, a couple of hintssorry Jey
He's gonna run a lincoln in the back.RockRanger said:I hate to tell you this Yomie but there is 3 lockers available currently for the rear. They are Lincoln, Miller, and Hobart.![]()
redranger4.0 said:i was told today the axles were put on hold till he gets back from cali
Hey 034x4, what is your front axle's pinion angle (if you know) ?034x4 said:I'm linking the front so I can correct the caster with no leaf/steering issues.
