034x4's D44 SAS thread... | Page 28 | Ford Explorer Forums
ohhhh, could it be a dodge axle?
could it be a Chrysler 9.25? man i have finals in two weeks, you gotta tell us. the economy will slow today cuz of what your doin...we arent gettin any work done.
^^No, but that's awesome. Never heard/seen those things. 1/2" thick housing, lots of clearance.... :cool:
and also 8 ujoints to break
lol, yep...spare parts are $$$$$ and no one will ever have what you need either...not a good buy...IMHO
it says it uses the 9" 3rd, and that definatly wasnt a 9" pinion
yea i know...i was just throwing it out there, everything i have guessed he has said no to... ;)
Nick26 said:
dodge/chrysler uses all danas i think.
nahh... they mostly use dana though.
i take it back on the 9.25, i do believe they have smaller shafts then the one pictured but hell im startin to give up
Suzuki Samuri?
Toyota?
Im going with late model dodge AAM or what ever it is they are called. That ring gear looks to be low pinion and have a speed sensor ring of some kind. The front axle looks to be of a unit bearing type of deisgn. The limit of 5.13 gears would also make me guess something new with not a ton of aftermarket support yet.
That is what I was thinking as well.
when are you gonna let the cat out of the bag ? we've suffered enough i think ?
It is land cruiser axles with a Birf eleminator kit. He is planning on putting a Sammi T case in it And that will line up with the off set cruiser axles. Then put an 8 to 1 gear set in the tcase and he will haveall teh crawl ratio he will ever need. Perfect setup.
You will have fun trying to drive it around so cal with your new setup. You will set the record for the most fixit tickets.
What's a Birf, and why eliminate it?
[QUOTE='97 V8]i take it back on the 9.25, i do believe they have smaller shafts then the one pictured but hell im startin to give up[/QUOTE]
he said it was bigger then a 10.25....so im geussing no.....btw i gave up long ago...maby an axle out of an f-550.......????
Found out for myself. Birf, short for Birfield or Birfield Joint. CV joint just like IFS explorer front ends. I guess these were used in solid axel applications in Toyotas.
