@Scotts96sploder I ask this question because yours is a '96 Explorer and mine is a '97 Mountaineer (1/2 year '96), Where your throttle body is bolted to the 90-degree curved plenum extension, was it nuts on studs or bolts? I'm not near my truck right now and can't remember exactly how it was configured, But I do know that my throttle body
DID NOT have a pre-heater built in. I'm making mental notes of the changes, the differences
year to year.
If you haven't ever had the curved piece detached from the upper plenum, The long studs going through it will have to come out to gain clearance.
Just carefully, slowly work them out so they don't break. If they won't come out, and you are taking off the upper plenum anyway, leave them in. *
Don't ever think that I know more about working on these old Explorers than anyone else. I'm learning about them too and just making suggestions at what to do.*
My studs came out clean from the upper plenum. I can see that if you can get the curved piece detached and clamp it up in a vice or turn it 90 degrees, and lag screw it to a work bench to hold it stable, maybe some heat around the area where the leftover bolt is stuck in the extension or use your favorite penetrating lubricant. If using heat be careful on the aluminum so that you don't melt it. The good thing about where they broke, there is enough bolt there sticking out to get
Visegrip pliers clamped on the piece of bolt after heating around on the aluminum outside of the threaded hole. Of course, chase the threaded holes with a good tap.
You have figured out by now that all 5.0 bolts have standard threads and not metric.
I'm talking to myself here now as if I was working on it, be patient.
