- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Yeah that! Thanks! I guess you have to clearance the engine mount and I can’t remember the filter number that fits but I’ll figure it out. Buddy says he’s running a 21178 hose that just has to be trimmed a bit to fit.He wants to put it directly on the block like the old days
Like this
Spark plug anti foulers cost a few $ and work just as well for those rear sensorsThe rear o2 sensors need to be in place to keep the PCM happy. I removed them on my 5.0 project that has the 1999 Crown Vic PCM, but they can be tuned out. I'll be using a 1999 Explorer 5.0 PCM for my second engine. I'm keeping them in place behind where the converters used to be to keep that PCM happy. I don't have access to tunable bin files for the Explorers. I'm not sure if anyone here has one either. PontiSteve in Ocala FL might can tune them out for you, if necessary, but it is probably at least $300.
Steve at Drag Radial Performance
pontisteve@earthlink.net
So if I plumb all 4 back in, but no cats, I’m still going to get a CEL?The rear o2 sensors need to be in place to keep the PCM happy. I removed them on my 5.0 project that has the 1999 Crown Vic PCM, but they can be tuned out. I'll be using a 1999 Explorer 5.0 PCM for my second engine. I'm keeping them in place behind where the converters used to be to keep that PCM happy. I don't have access to tunable bin files for the Explorers. I'm not sure if anyone here has one either. PontiSteve in Ocala FL might can tune them out for you, if necessary, but it is probably at least $300.
I sent you a message yesterdayI personally haven't gotten that far to be able to say. Did @Josh P send you a DM with the video that he sent to me?
I think I’m going to add a hanger off the frame for the down pipes. I’m about to get out there this morning and cobble together some scrap to make it work. I started by gutting a cat but then figured out the bodies are in the way for what I’m trying to do, so they are getting deleted.You for sure want the factory exhaust hangers at the trans mount, without that support in place (or something like it) the manifolds like to loosen up
Nice work this far! Tons of room for improvement from the factory pipes, they hang so low and the cats are right under and next to the converter and trans…. Silly ford
