Completed Project - Burns SAS thread | Page 19 | Ford Explorer Forums
Completed Project Burns SAS thread
Use this prefix for completed projects that are not "How to" articles or threads asking for help.
section525 said:
Are your shocks allowing enough up-travel?
i know that they are not the prob. they still have plenty of room to move. the track bar should not be the prolbem. the steering is a stock explorer bar with the lower bar that would orrginally be on the d44 front end. i think that the steering joints are not allowing the front to drop. how could i test. do i need to take the steering off and then see if i get more using a lift or something
Could the shock on the opposite side be bottoming out? You know, too big of a shock, the piston on the compressed side is bottomed out but the other side still has travel. you know what i mean?
yeah i have checked that out. there is still plenty of room for the shocks to move
i need a good way to drain the rear axle. after trying to swim in that pond i now have some water in my rear axle
just put a drain plug in, thats what i thought you were doing with that PS piece
cant u just remove the cover?
Ohhh right :D - the back is welded shut...
ok i have went all out and have now made a drain plug in the rear axle.... in the 3rd member on the pinon part with the five bolts i drilled upward in the bottom bolt. fluid is now draining slowly.
new seats and floor liner
The parts ranger i bought back in febuary had some nice seats. they have air controlls for the back and bottom. the only thing wrong with them is there is a crack in the plastic at the bottom of both seats were the air relase is at. I also have the console out of the ranger up front too.
For the rear i am putting the old front seats out of my X in the rear with the old console.
The carpet has been stripped because of the last time i went 4wheeling. i am lining the floor with spray on bed liner.
The liner is turning out nicer than i though
Wow, your going all out on this. I like it. Especially the rear captians chair idea.
I have already taken the time and have it all planned out. the rear console is mounted and i am going to have to make some brackets for the rear seats. I am going to use some flat and tube stock steel.
I have put three layers of liner in the rear i think i will finish it off with a fourth layer when i can do the whole floor so it will all look the same
i need to find a good place to get some flat top knuckles so i can do a better steering setup. i dont want to spend a fortune but i may have too.
Sky Manufacturing is what all the kool kats are running. :cool:
