Completed Project - Stic-o's 2nd gen. radius arm/coil SAS | Page 26 | Ford Explorer Forums
Completed Project Stic-o's 2nd gen. radius arm/coil SAS
Use this prefix for completed projects that are not "How to" articles or threads asking for help.
Well got the new manual T-case in over the weekend, kinda slacking other then that. Just spent a week working in vegas, so kinda just chilling this weekend.
On another note...This case is 1" shorter and 9 lbs. lighter then my old case.
nice... you got the boot and the shift linkage with it? that stuff is hard to come by..
and are you saying that the 1354 is an inch shorter than then 4405 or jsut the electric 1354 is a different size? I swapped a manual 1354 in for mt 4405 and don't remember there being any difference in length.
the newer('99) electric 1354 case is 1" longer, Then the Manual 1354('91-'94) I put in.
lookin good there stic-o. Can you do me a favor? If you can can you take a picture of the shift linkage (if the camera can see it). I'd appreciate it
Jefe said:
So Um. . .Are you done yet?
Well the plan was for it to be back home this weekend :rolleyes: But I over tighented a Special order banjo bolt for the front calipers and snapped it in half. :banghead: So the truck's not going anywhere this weekend. :(
as for a update...
we're welding the perchs in the morning, and mounting all the shocks. Rear driveshaft is in, after we made a custom 2" aluminum spacer for it. This is only temporary, until I can afford to order a new rear shaft. All the fluids are in - the rear axle. We'll start getting the front bumper back mounted tommorow as well. If there is time we'll get the sliders back on...I kind of need them to get in it now :D So after tommorow I'm just waiting on a bnjo bolt :rolleyes: Then we can bleed the brakes and she is good to go...for the street anyway ;)
Why is it that everyone els seems like they have to make a new tranny cross memeber and you didn't?
I am glad the t-case worked out for ya. :thumbsup:
Because my RA go father back then normal. I still may have to re do it though. I'm not sue if the front driveshaft will work with it at max flex :rolleyes:
Thanks Buddy, It went in really easy ;)
Monster Moves!
Although she never left the the driveway, she moved on her own power again today :bounce:
Today we finished the rear end. Perchs welded, axle filled with fluid, and shocks mounted outside the frame :D (pics coming soon) Started to get the shocks on the front and had to move some stuff under the hood, because the shocks are so long they go way up into the engine bay. Let's just say I understand now why Johnny (Section525) didn't use the 250 shock mounts :rolleyes: They're not long enough! We'll work on getting them in all the way next weekend, and she should be drivable on the street by then, once I get my Banjo bolt :rolleyes:
Now as for moing on it's own this weekend.... We need to move it so my dad could get his travel trailer out, so I said " well let's move it under it's own power, with no brakes..." So I jumped in and started it up...Now take note the Parking Brake does work, so this was are means of stoping it, and about four people with wheel chocks. Took off the PB, and put it in gear, and then just idle, it's started crawling over everything, curbs, up on to the flatbed trailer in front of it, the PB would bearly stop it. :eek: Welcome to 5.13's :D :thumbsup: I thought. So we were able to move it around just idlling and using the PB to stop it. It was interesting to say the least! But I'm very excited now, it truly will be a monster :D
Glad to see it finally moving on its own. Great choice on the gearing, I love the 5:13's in my Explorer. Now I just need to get the 4:1 ratio gear set for the NP231 transfer case and I will not have to worry about steep downhills anymore.
Sounds great! Can't wait to see it out on the trail:D :thumbsup:
RockRanger said:
I give it 5 trips till the body looks like jefes :D Looks good.
If we make him lead at Truckhaven, I bet we can get it in 4 runs.. Esp. the night runs down in the ruts.
This sounds like a challenge for all who dare; make the Stic-mobile look like Jefe's in as little time as possible. It already has the window basher rock damage from Calico, now we just need to scrape up the rest.
It will be a piece of cake if he doesn't finish his rock sliders.
You guys are hilarious :rolleyes:
Anywho..here are the pics I promised...
We're probally gonna have to re do these, though because, I'm pretty sure the tires will rub on the shocks. We'll see how bad it is. I think the tire will rub on the top of the wheel well first.
Also I don't think my leafs will last to much longer, they are starting to look like ocean waves :( I'll probally just find another set of explorer ones to put on for now.
Ah, the custom inverted W spring. They should flex great. :thumbsup:
Besides, they are still mostly positively arched, so you should be good for another year or so. :D
As for your rear shocks, yeah, those are going to cause you problems. Not to mention it doesn't look like you have enough up travel where they are currently mounted.
The angle will be hard to get with those mounts.
I've got the body lift on mine, so it was a lot easier to get the top of the mount up higher, plus they massaged the hell out of the inner wheel well to get them over the frame as much as possible.
It looks like you have the mounts at 12:00 you might have to clock them towards the back of the truck, like about the 2:00 position.
My rear springs look like that too, I learned in Moab that they load really fast & the front of the truck gets really light on steep climbs… That, plus too much junk in the back.
Next trip out there, I'm going to throw the spare inside & strap it down right behind the front seats.
