2002 Sport Trac SAS | Page 7 | Ford Explorer - Ford Ranger Forums - Serious Explorations
2002 Sport Trac SAS
2002 Explorer Sport Trac
Engine:
Stock 4.0
Taylor 8.8 MM Plug wires
Screamin Demon Coil
XCAL2 Tuned
Zabtek Cold Air intake
Random Tech "Y" pipe with custom FLowmaster exhaust. A few cats have been removed.
Transmission:
5R55E freshly rebuilt
1354 Borg Warner Electric Shift
Modified Superlift front driveshaft
Stock rear driveshaft
Front Axle:
89 Jeep Grand Wagoneer Dana 44 low pinion
ARB Air Locker
4:56 Ring & Pinion
Superior Chromo Axles
CTM U-joints
Steel braided 28” brakelines
Warn manual locking hubs
Parts Mike Highsteer arms with 1" spacers
Parts Mime highsterr knuckles
5/5.5 conversion kit
Rear Axle:
Explorer 8.8 31 spline
PowerTrax Locker
4:56 Ring & Pinion
SOA conversion
Wheel spacer/adapter for 5/5.5 bolt pattern
Suspension:
BDS front shocks
Rancho RS5000 rear shocks stock height
Custom made 7 pack Waggy leafs up front
Stock leafs out back
Tires and Rims:
35x17x12.5 BFG KM2
Eagle Alloys model 951 17x9
Body Mods:
3" Body lift (may come out soon to allow for more suspension lift)
Clear corner lens
Sylvania Silverstar 9007 headlight bulbs
Sylvania Silverstar 9005 foglight bulbs
Sound System:
Kenwood head unit
(4) 6x9 Ifiniti speakers
(2) 8” Kicker Subs in a custom figerglass enclosure behind the rear seats
Alpine 4 channel Amplifier
Cobra 75WXST CB
Here is my build thread, I will apologize now for the stupid questions you will read from me..
http://www.explorerforum.com/forums/showthread.php?t=237526
There are a bunch of interior mods i did but this a SAS registry..
First was the install of the crossmember:
Then followed alot of cutting and grinding to get here, where the rear leaf mounts were installed:
Then a little more progress:
Steering was a PITA. Here is my Gen1 and Gen2 Hybris steering linkage:
Here is the Rack and Pinion steering cooler re-used and mounted to my crossmember:
More progress:
All this work to get here:
crazyflights
St. Joseph, MO
97 1 ton Jeep
Just found few pics I wanted to add.
crazyflights
St. Joseph, MO
97 1 ton Jeep
O and thats to get you thinking Chad..... LOL we need to hit Flat Nastys???
BlakeGordon
Tarpon springs FL
'01 XLT
How did you run your power steering?
SKYNET808
Flori-duh
07 ST V8 4x4 on 33's
fantastic truck - - great inspiration!
were you able to run 33 (or 35 in your case) with just the 3" body lift?
pauley
Madison, Wisconsin
93 xlt
that rig looks damn good. i miss my truck so damn much
00whxploder
Fitzgerald, GA.
2000 xls 4x4 now
What about steering from fire wall to box?
00whxploder
Fitzgerald, GA.
2000 xls 4x4 now
thanks buddy that help out a lot
J_Train
Citrus Springs, Florida and LaGrange, Georgia
00 xlt v8
Shortly before this picture was where I was pretty nervous for ya- Chad and I wasnt even in your truck :)
How much of a slope/angle/grade whatever was that?
J_Train
00 xlt v8
Damn the First 100+ feet looks to be about the steepest. i bet it takes a lot of patients.
LONO100
Bay Area CA
03 sport trac XLT
i know you used waggy leaf packs for your swap, i was doing some research on swapping in a D30, any suggestions on the kind of leaf packs i should use for that type of axle?
chad551
St.Louis, MO
The axle does not change the type of leafs. So I would use the waggy leafs.
MidnightRebel07
Pittsburgh, Pa.
2003 Explorer Sport Trac
Yep, use Waggy packs or a heavier truck to support the weight of the ST.
LONO100
Bay Area CA
03 sport trac XLT
I guess what I'm really asking is what would be some alternative vehicles that I could find some suitable leaf packs for this swap being that the waggys are few and far between in my neck of the woods.
SVO42
RV Nomad
1994 XL
Any springs from a stock Waggy are going to have the infamous "Wag sag." I've had my own Waggy, sold it to my dad, and he got two more. I used Waggy springs for my SAS, but I got new ones from BJ's Offroad: http://www.bjsoffroad.com/. The guys that own it are FSJ enthusiasts and great to work with. I got front 4" lift springs and used them SOA. I still need to work a bit on my shackle length and angle but they're great. Nice and flexy. With my front custom crossmember and that combo I got about 8" of total lift in front.
